| Ace Le Count |
Jun 2 2026, 12:55 AM
Looking for 4712908713 ![]() ![]() Group: Members Posts: 200 Joined: 20-February 18 From: Golden Valley, AZ Member No.: 21,910 Region Association: None |
The gas pedal requires a bit of effort to push down and doesn't really want to come back up. I will look into it some more tomorrow. The crossbar almost seems like it needs to be lowered because everything is so darn tight. Almost like the throttle cable isn't long enough. Just wanted to throw this out there before I keep messing with it tomorrow.
https://drive.google.com/drive/folders/1y5Z..._uKNzK7YjHYnc2n |
| barefoot |
Jun 2 2026, 05:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,517 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Can't see the arm for the 3-4 side carb link, but they should sit horizontal or slightly upward throttle off, most use an extra return spring in addition to the carb springs.
The arm for the cable should be beyond vertical for greatest leverage. Moving the attachment bracket aft will allow you to re-position the cable longer. |
| Ace Le Count |
Jun 2 2026, 12:15 PM
Okay. I did some finagling and it turns out I had one of the Pittman arms upside-down. The throttle cable is still tight at the pedal and it also seems to be too short... (IMG:style_emoticons/default/confused24.gif)
Also, I updated the link with fresh pictures |
| porschetub |
Jun 2 2026, 06:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,115 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Okay. I did some finagling and it turns out I had one of the Pittman arms upside-down. The throttle cable is still tight at the pedal and it also seems to be too short... (IMG:style_emoticons/default/confused24.gif) Also, I updated the link with fresh pictures Don't you mean the throttle arm that connects to the drop link on to the carb/s ? . Your geometry isn't great and IMO is the cause of your issues , I can only think the low mounted crossbar is there so you have clearance for the cooler fan and the use of short inlet manifolds sort of confirms that . If you are happy to tinker with this system constantly to setup right that's fine but end result will be marginal @ best even with the correct length cable . If you want a better solution i would say the CSP bellcrank system from 914werke is the way to go ,Rich the seller would have a solution for a cable I would think. I used a bellcrank setup on my last customer build and was amazed how easy it was to setup . Up to you and good luck ,cheers . |
| 914werke |
Jun 2 2026, 08:03 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,676 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
I see too many of these janky Throttle cable mounts.
That thing needs to me RIGID ! the one I make is solidly mounted & forces you to center your setup |
| Ace Le Count |
Jun 2 2026, 08:31 PM
Update: the pedal cluster was having some issues. I have another thread here that you can refer to. By messing with that, I was able to unsnag some cable and got just the right amount. At least She's running now!
| porschetub |
Jun 3 2026, 05:32 PM
Update: the pedal cluster was having some issues. I have another thread here that you can refer to. By messing with that, I was able to unsnag some cable and got just the right amount. At least She's running now! Good start ,if you have enough spare cable try to bring the throttle arm back on the crossbar to a more vertical position or further back as barefoot mentioned ,get the pedal throttle arm straight as the cable will create drag in the tunnel cable tube ,if it free's up further put a spring on the throttle arm and ditch the extra spring/s on the carbs , those will only compound your issues . Found your pedal thread and yes get a rebuild bush kit and DIY or farm out to Bruce for rebuild he is the expert for sure . Good luck moving on ,cheers. |
Lo-Fi Version | Time is now: 4th June 2026 - 12:23 PM |
