| DeWitt |
Jun 4 2026, 06:52 PM
Newbie ![]() Group: Members Posts: 13 Joined: 25-August 24 From: Lancaster County, PA Member No.: 28,309 Region Association: North East States |
I just completely removed and replaced the glass and window regulators in my 1973 2.0. I dove in because the driver's window, in particular, has a tight spot when raising. Here's what I've done.
1. Replaced the rollers with new parts from 914 rubber. 2. Checked the regulator for binds and play - all seems good. 3. Cleaned all the roller tracks, and blasted and painted the rusty short tracks that bolt to the door. 4. Lubricated everything. I used Super Lube with PFE for the rollers and tracks, and 3-in-1 Window & Track Dry Lube in the glass tracks. I chose both after Ai searches which recommended them. 5. Carefully aligned glass tracks. It works really well on the passenger door. On the driver's door, when raising it binds around 1/4 of the way up, and requires more effort to get past the tight spot. Then it's fine again. While I had everything apart, I compared the arc of the two front tracks, and they aren't quite the same. I can't imagine how one or the other could have gotten bent - it's a U-channel with no access for damaging force. Has anyone tried re-arcing one of those tracks? The glass on the driver's side fits in the frame very well, perhaps even "perfectly." The quarter window fits tight at the windshield, and the door glass fits at the top and back. This isn't a shop-stopper, but I'd love to get the driver's door as easy to raise as the passenger door. Any ideas or advice? Many thanks! Cheers, Emery ![]() |
| rgalla9146 |
Jun 5 2026, 05:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,970 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
There is an 'in / out' adjustment at the bottom of the forward guide, could it be too far in one extreme ? Your door is the later version right ? |
| Spoke |
Jun 5 2026, 06:32 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,398 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Does the window bind with the door open?
The passenger window of my 911 goes up and down very easily with the door open but struggles to go up with the door closed. |
| 914werke |
Jun 5 2026, 07:45 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,679 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
assume these are early (cable) regulators since you refer to the rollers & "short" tracks.
| DeWitt |
Jun 5 2026, 04:00 PM
There is an 'in / out' adjustment at the bottom of the forward guide, could it be too far in one extreme ? Your door is the later version right ? I adjusted that to fit well with the windshield, but you've given me an idea. Next week I'll adjust the track in various positions, and see if the binding changes with the door open. Perhaps the windshield frame is pushing on the track, torquing it. |
| DeWitt |
Jun 5 2026, 04:01 PM
Does the window bind with the door open? The passenger window of my 911 goes up and down very easily with the door open but struggles to go up with the door closed. Yes, it binds with the door open also, but perhaps a little less. See my previous response for an idea I'm going to try. |
| DeWitt |
Jun 5 2026, 04:05 PM
assume these are early (cable) regulators since you refer to the rollers & "short" tracks. No, my '73 has the scissors-style regulator. The "rollers" I'm referring to are the two plastic (Delrin?) bits that press onto ball studs on the regulator. https://914rubber.com/window-roller-for-sci...-type-regulator The "short track" is the one that captures that roller toward the rear of the door. It allows adjustment for the tilt of the top edge of the window. |
Lo-Fi Version | Time is now: 7th June 2026 - 01:59 PM |
