| rfinegan |
Jun 10 2026, 11:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,204 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Looking for a valve guide boss cutter for 914 heads with 8/9 mm pilots to cut the valve guide boss for the Porsche 914 -4 2.0 l heads. MY springs are tight on bosses and need a little timing to fit
Buy rent or borrow most likely one time use -Robert |
| zig-n-zag |
Jun 12 2026, 06:17 PM
Member ![]() ![]() Group: Members Posts: 209 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
The valve guide boss cutter is available at GeneBerg.com.
They also have the 9mm pilot so you’re able to cut the exhaust guide boss On the type 4 head as well. |
| Jack Standz |
Jun 12 2026, 11:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 823 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
+1 on the Gene Berg tool.
We have one and it worked just fine, but IIRC both valves were 8mm on the head it got used on. |
| saigon71 |
Jun 13 2026, 04:56 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,026 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
I just went through this.
If interested, the SCAT 20011 single hi-rev valve springs have a slightly larger inside diameter (.930) and fit without any trimming of the giude boss. |
| rfinegan |
Jun 13 2026, 05:50 AM
correct springs and H/W and not t1 springs may be cheeper that retooling
I have the empi/jbugs 4045 single high rev I got from PMB |
Lo-Fi Version | Time is now: 13th June 2026 - 02:54 PM |
