> Still having idling issues!, Less, but still some
detective_snakes
post Jun 12 2026, 02:36 AM
Hello! Yes yes! I've at least somewhat fixed the problem the mechanic handed me. I replaced the carburetor that was spitting fuel everywhere, cleaned up the battery terminals, and it starts! However, I'm back again to the issue where it doesn't idle for very long. I got it to idle a hell of a lot longer than the mechanic did, which is nice, but it still does die. So, up until now, I've...
- cleaned the fuel tank
- installed new fuel hoses (rubber, not the metal ones)
- installed a new rotary fuel pump + filter
- cleaned the hose junction
- balanced the carbs, tuned them to something that *should* at least work (zeroed, 1+1/2 turns out, 1/4 turn back in)
- installed new carburetor/manifold gaskets
The left carb still 'burps' sometimes and spews some white smoke. I suspect that I need to adjust the timing. In the meantime, do you figure I should try different distributor cables, a new head temp sensor...? I can't really think of many parts this could be. I already replaced the distributor as is, plus the ignition coil and a few wires.
Also, I'm sure it's fine, but only one carb is hooked up to the dizzy for vacuum. The other one I can just leave open?
Again, a massive thank you to everyone who helps. You are lifesavers.
detective_snakes
post Jun 12 2026, 02:38 AM
I should mention that I'm pretty confident that this isn't a deeper engine issue. The first time I got it back from the mechanic to clean out the fuel tank, it actually did run perfectly fine. Idled and all. We only had to take it back to re-clear the fuel lines because a bit of gunk got stuck in the metal tubes. But it never really worked again after his second round of work. I don't think it's a compression problem or anything.
rfinegan
post Jun 12 2026, 10:19 AM
FWIW:
Idle jets on the IDF Webers plug up frequently, some times daily til all the junk and slime works it way out of the fuel system. A cheep in line file will helps and replace frequently till fresh fuel is sampled and the obstructed jet problem goes away. Dirty environments is a little different issue and dirt can plug an idea jet too from under the air filters, I carryed a small sample on copper wire and would clean my jets on the side of the road or parking lot prior to my commute home from work only takes a moment or two
2) Getting the base throttle plate set below the transition holes is what its all about with Webers... lots of good tuning techniques here on the world
Dave_Darling
post Jun 12 2026, 02:09 PM
914 Idiot
A note--the CHT sensor is not used for carburetors. Not sure how you would have it plugged in, even, as it plugs into the fuel injection wiring harness...
--DD
rfinegan
post Jun 12 2026, 05:59 PM
no open vacuum ports!
porschetub
post Jun 13 2026, 12:13 AM
QUOTE(rfinegan @ Jun 13 2026, 11:59 AM) *
Not much info from the OP ,to really help we need a whole heap more info to even get a baseline ;
Carb brand and size ,
pump type and pressure rating ,
carb balancing ,
what distributor ,
timing setting ,
All you can supply will sort your issue with the help of members on here,cheers.
- Lo-Fi Version Time is now: 13th June 2026 - 02:56 PM
