| young55961 |
Jun 18 2026, 02:34 PM
Newbie ![]() Group: Members Posts: 33 Joined: 15-March 18 From: Arcadia Member No.: 21,972 Region Association: Southern California |
I have a question about the ECU wiring harness.
There are three pairs of white wires with female spade terminals on the harness. I believe they are the ground wires for the fuel injectors, but I can't find where they are supposed to connect. Should these wires be connected to the negative (-) terminal of the ignition coil? If anyone has a photo showing the correct connection, I would really appreciate it. Thank you! |
| brant |
Jun 18 2026, 02:46 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,213 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
There was supposed to be a three prong connector on the rear engine block through bolt
Back center of engine bay |
| JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,283 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
2 of the three pairs are injector grounds. The third pair is grounds for the ECU and TPS.
They attach to a Tri-spade male terminal located on an engine case through-bolt at the top rear of the engine case, under the air plenum. |
| young55961 |
Jun 18 2026, 02:52 PM
| Ishley |
Jun 18 2026, 08:12 PM
Member ![]() ![]() Group: Members Posts: 354 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
Here is what you’re looking for in the yellow circle.
| young55961 |
Jun 19 2026, 10:54 AM
| Jack Standz |
Jun 19 2026, 03:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 843 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
It's easy enough to get one. Here's one example, but there are others available:
https://www.ebay.com/itm/168409193204 |
Lo-Fi Version | Time is now: 19th June 2026 - 03:53 PM |
