| Dominic |
Jul 5 2026, 04:11 PM
Dominic ![]() ![]() ![]() Group: Members Posts: 997 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
For Sale: Used Tach-Adapt, bought from another world member several years back.
$50 shipped in CONUS FYI, I found this description from another website. Porsche TACH-ADAPT.....the little black box that makes your tachometer work right! This digital tachometer rate adapter makes your existing tachometer display correctly on any four, six or eight cylinder engine. This adapter goes in line with your current tach signal and changes the voltage. The pulse rate conversion feature makes it possible to match your vintage tach to a four, six or eight cylinder engine. This item is easy to install and can be concealed in the instrument panel or mounted to the engine compartment. This item has a four wire connection and works with points, electronic ignition or CDI systems. The pulse restoration allows the tach to to trigger properly from modified ignition systems. The pulse filtering system cleans up waveforms and cleans up erratic behavior. This item fits all models, including 356 models that have upgraded from a 6V system to a 12V. SPECIFICATIONS: Input: Points, Electronic Ignition, CDI or Engine Control Module Tach Output: Current limited 12V square-wave with selectable leading edge high-voltage pulse (for most vintage tachs) Rate Selection: Switch settings adapt a 4, 6 and 8 cylinder input to 4, 6, or 8 cylinder tachometers. Power: 12V, approximately 25 mA. Connection: 4 wires (power, ground, signal in, signal out) connect to screw-down block. Case Size: 2 x 1.5 x 1 inches. (51 x 38 x 25 mm), flanges for easy mounting. Attached image(s)
| rgalla9146 |
Jul 6 2026, 06:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,977 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
pm sent |
Lo-Fi Version | Time is now: 7th July 2026 - 09:52 PM |
