| burlybryan |
Jul 18 2026, 03:49 PM
Member ![]() ![]() Group: Members Posts: 159 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
Hole is elongated. I could weld it up and re-drill if needed.
| HFC3 |
Jul 18 2026, 06:54 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 14-December 25 From: Virginia Member No.: 29,151 Region Association: MidAtlantic Region |
There’s certainly people on here that could have that welded it up and then re-drill it.
That hole obviously needs to be dead nuts. I believe that is the one set point on the trailing arm that has no adjustment. |
| bkrantz |
Jul 18 2026, 08:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,739 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
There’s certainly people on here that could have that welded it up and then re-drill it. That hole obviously needs to be dead nuts. I believe that is the one set point on the trailing arm that has no adjustment. Unless you want some "adjustment". I might have known people who might have gotten more camber in near-stock race 914s by "moving" the hole. |
| bdstone914 |
Jul 18 2026, 10:10 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,340 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@burlybryan
date='Jul 18 2026, 02:49 PM' post='3265550'] Hole is elongated. I could weld it up and re-drill if needed. [/quote] Replace it. Which side is it? Can you show a whole picture of it? I have a few.. |
| bdstone914 |
Jul 19 2026, 03:58 AM
[quote name='bdstone914' date='Jul 18 2026, 09:10 PM' post='3265574']
@burlybryan date='Jul 18 2026, 02:49 PM' post='3265550'] Hole is elongated. I could weld it up and re-drill if needed. [/quote] Replace it. Which side is it? Can you show a whole picture of it? I have a few.. [/quote] What does the end of the pivot shaft look like that was caused that oval hole? My quess it it iams damaged. Is it grooved or are the serations on the end worn off? |
| burlybryan |
Jul 19 2026, 09:39 AM
Hi Bruce. Thanks for the offer. The console on the car is also elongated, so I'm going to weld them and re-make the holes.
The shaft is also worn, so I may as well get new set from 914rubber. I haven't torn down the drivers side yet, but assume it's in similar condition. Bryan |
Lo-Fi Version | Time is now: 20th July 2026 - 03:45 PM |
