> Gears not shifting into 4th & 5th + other issues into 1-2-3, Gear shiffing advice on Parts & Repairs on my 1974 914-4
TJB/914
post Jul 20 2026, 10:51 AM
Mid-Engn.
Took my 914 out for a cruise yesterday & had shifting problems on the highway with no 4th or 5th gear shifts. In the garage at startup gear shifting (wobbly) was loose into all gears. On the highway 1st. 2nd & 3rd was ok but nothing into 4th. or 5th.?
Need advice where to look & start for repairs.
914's are so low, getting under the 914 has issues for inspections as I get older (IMG:style_emoticons/default/headbang.gif)
Tom, Looking for 914 repair shops in the Petoskey MI area is difficult.
brant
post Jul 20 2026, 11:01 AM
Start with bushings and the shifter linkage set screws
Likely a set screw came loose
Or a bushing disintegrated
friethmiller
post Jul 20 2026, 11:22 AM
I had this same problem where it just starts happening - where it was working fine before. I bet its the cone screw at the transmission linkage. Use blue locktite!
brant
post Jul 20 2026, 12:17 PM
TJB/914
post Jul 20 2026, 12:36 PM
Mid-Engn.
QUOTE(brant @ Jul 20 2026, 02:17 PM) *
Appreciate everyone's help.
Now I need to find a lift to make it easy.
More later after it's fixed.
Tom
FlacaProductions
post Jul 20 2026, 03:03 PM
pull back the boot on the engine side of the firewall around the shift rod. I'm going to bet the bushing there is in pieces...
windforfun
post Jul 20 2026, 03:07 PM
QUOTE(FlacaProductions @ Jul 20 2026, 02:03 PM) *
And you don't need to remove the rod. Get a new nylon bushing & slice the wall open at 45 degrees. Voila!!! Push it in & you're good to go. BTDT. Easy repair.
NARP74
post Jul 20 2026, 03:31 PM
I built a set of wheel cradles out of scrap wood for this issue. Can get it a foot off the ground with 2x4 and 2x6 lumber, stackable and very stable. Race Ramps if you have the $$$.
Luke M
post Jul 20 2026, 03:32 PM
QUOTE(TJB/914 @ Jul 20 2026, 09:51 AM) *
Check out Munk's Motors in Waterford, MI. : https://www.munks.com/
They fixed my old Audi Q7 when I was visiting family in MI.
They also had a few 914s in the shop when I was there last.
Otherwise I think McMark is in Grand Rapids?
emerygt350
post Jul 20 2026, 05:35 PM
I have a couple cheap drive on AutoZone ramps. That works for this cone screw job. I will put the floor jack under the driver's side as well for even more room. Hardest part is getting the boot back on the firewall. Fold the rubber back a little bit press it in place and let it flip back over the firewall lip is my trick. Some days it goes better than others.
HLANG
post Jul 21 2026, 06:30 AM
Region Association: Germany
I had the issue several times and it can have different root cause. If it got worse over time then it is most likely a bushing issue. The centre bushing btw. the cabin and the engine department is most important. If it is worn out shifting gears become gambling. But could also be the bushings in the shift gate or the plastic bushings at the gearbox itself.
If you experience a shifting issue out of the blue it is most likely no bushing issue but a connection became loose. Could be the whole shifting stick mechanism which is screwed to the chassis or any screw that is sitting on the shifting rod. In my case, I remember that 4th and 5th gear issues always disappeared after put in the second gear, opened the M8 screw between gear stick and shifting rod, aligned it and screwed it tight.
In the meantime I have improved the entire shifting mechanism. Let me know if you are interested.
TJB/914
post Jul 21 2026, 12:34 PM
Mid-Engn.
QUOTE(HLANG @ Jul 21 2026, 08:30 AM) *
HLANG
I agree this is probably the problem after all forum advice (IMG:style_emoticons/default/pray.gif)
I'll now take it slow with this shifting assembly problem (IMG:style_emoticons/default/headbang.gif)
I am almost 90-years old & don't want to fix 914 repairs at this time in my life. Safety is important & looking for a repair shop near is difficult finding trustworthy people.
The closest Porsche (air Cooled) shop repair is 70-miles from home is bookings now in October 2026.
I'll fix it in my spare time (IMG:style_emoticons/default/wacko.gif) or sell it, Maybe as is (IMG:style_emoticons/default/popcorn[1].gif)
Tom
dtmehall
post Jul 22 2026, 08:09 PM
TJB/914
i am down in se michigan
is there anything i can help with?
- Lo-Fi Version Time is now: 23rd July 2026 - 01:17 AM
