| GeorgeKopf |
Jul 20 2026, 02:35 PM
Member ![]() ![]() Group: Members Posts: 263 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
I've got a nice late model center rear view mirror (the one attached to the windshield) but the glass is dull with yellow streaks and spots. Is it possible to replace just the mirror inside the plastic frame? Perhaps heating up the plastic to allow inserting the new glass?
Thanks. George |
| Cairo94507 |
Jul 20 2026, 02:52 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,720 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
The later mirror is available new for a few hundred dollars. I am not sure you could get the old glass out of the mirror without damaging the plastic mirror itself. (IMG:style_emoticons/default/beerchug.gif)
| 914Sixer |
Jul 20 2026, 04:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,523 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
NO
| GeorgeKopf |
Jul 20 2026, 04:38 PM
Thank you both.
George |
| mepstein |
Jul 20 2026, 06:08 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,832 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I haven't seen it done successfully.
| HugoNL914 |
Jul 21 2026, 02:42 PM
Newbie ![]() Group: Members Posts: 13 Joined: 30-May 22 From: Netherlands Member No.: 26,583 Region Association: Europe |
I have to disagree. I have replaced the glass of the rear view mirror. Mine was also full of spots and not nice to see. Got it out and ordered a replacement mirror here at a local shop using the old one for size. Fitting it was tricky but doable.
You some patience and to be very carefull. Use plastic flat sticks like the ones you get for mixing two component glues to get de glas to slide in position. |
| mepstein |
Jul 21 2026, 03:00 PM
I have to disagree. I have replaced the glass of the rear view mirror. Mine was also full of spots and not nice to see. Got it out and ordered a replacement mirror here at a local shop using the old one for size. Fitting it was tricky but doable. You some patience and to be very carefull. Use plastic flat sticks like the ones you get for mixing two component glues to get de glas to slide in position. (IMG:style_emoticons/default/beerchug.gif) |
| 930cabman |
Jul 21 2026, 06:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,765 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I have to disagree. I have replaced the glass of the rear view mirror. Mine was also full of spots and not nice to see. Got it out and ordered a replacement mirror here at a local shop using the old one for size. Fitting it was tricky but doable. You some patience and to be very carefull. Use plastic flat sticks like the ones you get for mixing two component glues to get de glas to slide in position. Being a glass/window guy my gut was telling me yes. Surely it's not a task to complete with your eyes closed. Great victory. (IMG:style_emoticons/default/beer.gif) I'll try to save a couple hundred bucks wherever I can |
Lo-Fi Version | Time is now: 26th July 2026 - 07:26 AM |
