| NARP74 |
Aug 5 2026, 11:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,521 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I'm not there yet but soon. I remember the last time I messed with the front turn signal connections it was a frustrating exercise with colorful language involved. I'm saving this part of the rabbit hole I am in for last.
Any tips to deal with the tight, dark, need three hands operation of connecting them? |
| JeffBowlsby |
Aug 5 2026, 12:47 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,327 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
| NARP74 |
Aug 5 2026, 03:38 PM
I am mostly concerned with the how do I get my hands and fingers in there to make those connections with the rubber boot and other obstructions in the way.
Jeff, I have used your resources consistently for many years. Thank you for all of them. |
| JeffBowlsby |
Aug 5 2026, 03:53 PM
Remove the TS bucket, make the electrical connections, mount the boot, reinstall the bucket.
| 930cabman |
Aug 5 2026, 03:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,777 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
IIRC I followed Fred when I recently did mine. cut the wires, remove the assembly, thread the wires into new rubber, get them back on the car, solder/heat shrink tubing. It's not one of the more fun projects, but if I can do it anybody can.
recalling now, I might add a couple (2) inches to the individual wires to help with the install. I like soldered connections with heat shrink tubing |
| NARP74 |
Aug 5 2026, 04:56 PM
I will try what @JeffBowlsby said. That is basically what I did to remove the bucket for testing. Maybe that and a long pair of right angle needle nose pliers.
@930cabman , I have been up to my ears with cutting and fixing connections, I just want to climb out of this rabbit hole. |
| NARP74 |
Aug 6 2026, 05:33 PM
Managed to get it hooked up. I found that pulling on the wire bundle near the headlight gave me more slack to pull some wire through. And of course having the wheel off gave me room to move and a place for the light.
Lo-Fi Version | Time is now: 7th August 2026 - 11:13 AM |
