> Major difficulty getting into reverse and first. It was working and then it wasn’t.
914xr75
post Aug 5 2026, 12:14 PM
My daughter’s 73 is having a very hard time shifting into reverse and first. A couple years ago I replaced all the bushings down below, but I did not replace anything in the console area.
While going about 2 miles an hour, I can get it into first, but reverse is very difficult. I’ve got it up on jackstands right now and I’m about to put my level one mechanical eye on it. Just thought I’d throw this out in case anyone knows what I need to look for before I get down under Lil’s 914—-again.
She’ll be helping me this time.
Jack Standz
post Aug 5 2026, 02:56 PM
Maybe the first place to look is where the front and rear shift rods connect under the rubber boot by the firewall. Is the cone screw loose? Also, check the bushing there and all the bushings back to the transmission.
mark04usa
post Aug 5 2026, 03:00 PM
'70 1.7 Tangerine
Be sure that the clutch is disengaging. If out of adjustment, or if the clutch cable tube has broken loose, could be cause of your 1st/reverse problem.
worn
post Aug 5 2026, 05:03 PM
QUOTE(mark04usa @ Aug 5 2026, 02:00 PM) *
One additional thing to look at are the mounts for the motor and transmission. If these loosen or fail the geometry of the shift rod heading to transmission can change. Look at bushings first, but might also look at the mounts to be certain. I found out about this in Nebraska, returning from the west coast to Wisconsin.
914xr75
post Aug 6 2026, 10:28 AM
Super easy fix— the cone screw where the shift rod connects to all the bushings at the rear was loose. Got a big smile on my face when I saw how loose it was.
Nice to have first in reverse back. Thank you everyone for your help.
brant
post Aug 7 2026, 06:43 AM
You should replace that cone screw. Or at least lock-tote it
It’s a self locking screw by design and meant for one time use
If it came loose then it’s not its first use
- Lo-Fi Version Time is now: 7th August 2026 - 11:13 AM
