 Forum Rules Classified Rules!
> 72 Light Ivory in Vegas, clean title lots of potential 2k
Graydingo
post Aug 11 2026, 10:40 PM
For sale 1972 Porsche 914 in Light Ivory that has been partially resprayed in red. Trunks other areas remain original color.
This is a project car that someone started to strip down. It's a roller with full suspension (sans rear brake calipers).
It includes a Porsche 914 1.7 motor. I have the original tail shift transaxle as well.
I have all the glass for it including a better front windshield with a very minor crack at the base.
A lot of the core interior is there too. Has 72 seat backer core, but I also have a 74 core and seats I can include if you want them. Various interior bits in rough/core condition are there as well.
There's a good pedal box and accel pedal, brake lines, brake MC and reservoir setup for reference, 901 shifter, rearview mirror, chrome bits like the sail pieces etc.
It's on 15" AWC Fuchs style cast wheels. I have a second set of wheels maybe the original you can have either or.
Some core gauges present, bumpers, turn signal housings, two gas tanks to choose from and a whole other 74 914 that I'll let you choose any parts off of. For example, the door on the 72 is not so hot, if you want to swap the doors, you can. I only need front end metal from the donor 74 that has no title.
I also have upgraded 911 front end that I can sell separately if interested. Start that 5 lug conversion.
Overall, this car seems really dry compared to a lot of early 914s I'm seeing on Youtube. There's a section on the passenger firewall low that will need to be cut out. I didn't see anything else major that would require cutting. The hell hole needs a new battery box mount avail from Restoration design. The metal under it seemed fair to good.
PO took the rear decklid bolts out of the hinges, I'll fix that so the decklid closes properly. Also the hood is the donor hood off the 74. It's in great shape.
I have a chrome front and two chrome rear bumpers and used bumper tops.
I have a tow truck driver who is very reasonable can transport at your expense.
2k OBO
- Lo-Fi Version Time is now: 14th August 2026 - 05:55 PM
