| DennisV |
Aug 14 2026, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,029 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram.
They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() |
| Luke M |
Aug 14 2026, 07:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,591 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
Yes, they are special thick washers. Pm Bruce Stone I'm sure he has a few hanging around. (IMG:style_emoticons/default/beerchug.gif)
| DennisV |
Aug 14 2026, 07:41 PM
Yes, they are special thick washers. Sigh. Thanks. Good to know. If anyone can share the spec that would be greatly appreciated. I'm going to install the engine tomorrow. I have a bag of thick washers I could potentially modify if I knew the correct thickness and OD. |
| Cairo94507 |
Aug 19 2026, 08:10 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,758 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I recall them being about 3/16" thick. Good luck.
| Flyinlow |
Aug 19 2026, 05:11 PM
Flyinlow ![]() ![]() Group: Members Posts: 169 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram. They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() Hi… the washers are 40 mm O.D. 12 mm I.D.and 5mm thick |
| DennisV |
Aug 20 2026, 08:47 AM
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram. They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() Hi… the washers are 40 mm O.D. 12 mm I.D.and 5mm thick Thank you! I'll add this info to the parts vault. The one's I made were 41.7 mm OD, drilled to 12.7 ID, and a 4 thick washer. So I'll probably roll with this for the foreseeable future. |
Lo-Fi Version | Time is now: 9th September 2026 - 09:54 PM |
