| LikesSummer |
Aug 21 2026, 12:03 AM
Newbie ![]() Group: Members Posts: 12 Joined: 27-March 26 From: Ontario, Canada Member No.: 29,327 Region Association: Canada |
The trunk light in my 72 does not seem to work. First thing to check is the bulb, of course. Easy to get the little module out that sits behind the trunk wall, but then how do you get at the bulb?? The module seems like a single, sealed unit.
This 22 year old thread asks the same question, but then doesn't really give an answer. Anyone have any wisdom here? I can't drive the car without a working trunk light, after all. |
| Shivers |
Aug 21 2026, 02:04 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,541 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| bdstone914 |
Aug 21 2026, 03:12 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,359 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Push twist
Sometime the bulb corrodes in the socket. Squirt some penetrating oli on it |
| LikesSummer |
Aug 21 2026, 11:24 PM
Thanks both for these great answers. All the plastic is so old, it's like a time traveler. You really want to know if someone has done something you're thinking of doing before so that you don't risk wrecking something old but working. I prefer to not re-invent the wheel if possible. Amazing help. Thanks again.
| JamesM |
Aug 21 2026, 11:34 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,290 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Thanks both for these great answers. All the plastic is so old, it's like a time traveler. You really want to know if someone has done something you're thinking of doing before so that you don't risk wrecking something old but working. I prefer to not re-invent the wheel if possible. Amazing help. Thanks again. My solution is to spend 28 bucks https://pmbperformance.com/products/rear-lu...bb10a&_ss=r |
Lo-Fi Version | Time is now: 22nd August 2026 - 07:35 PM |
