> Speedo Cable Boot and Clamp on 914-6
DennisV
post Aug 21 2026, 09:38 AM
1. Is the transaxle side of the speedometer cable meant to have a boot? I have seen one on a couple of cars that seem very original (photo from BaT, not my car). I don't see it listed in parts catalog. I bought a new speedo cable. It came with a boot for the firewall side. Nothing for the transaxle side.
2. The nut on the speedo cable has a couple tabs and small holes. Almost like safety wire holes. Do they have a purpose?
3. Is the clamp that holds the speedo, clutch, and accelerator cables something special? I could not find a way to orient a common Norma clamp to attach to the bracket in a way that is oriented for the cable direction. The clamp opening would be running perpendicular, instead of parallel to the cable run.
Thank you.
mskala
post Aug 21 2026, 12:26 PM
R
I personally have never seen a rubber boot on the angle drive nut. However, the
diagrams seem to show it as part of the cable (single part #) so maybe it only came
on stock cables produced back then.
Also the nuts I have used never had tabs.
For the clamping of all the 3 cables, this picture is how I have used the clamp with
a small aluminum extender. The stud was removed in favor of short bolt. You may
need to alter this because I am obviously using headers here. I also put some slit old
fuel lines around cables for more protection.
Mark S.
rgalla9146
post Aug 21 2026, 04:15 PM
Correct OEM speedo cables have not been available for years .
The originals had a different alloy nut with a rim to hold a proper boot.
Same for 914 6 clutch cables which were larger dameter cable than those for
four cyl cars.
Want to post pics but my laptop is misbehaving.
914Sixer
post Aug 21 2026, 06:28 PM
Rory is correct, Original cable ends had wingnut type and a rubber boot
- Lo-Fi Version Time is now: 22nd August 2026 - 07:35 PM
