> Next problem!, Question
Flyinlow
post Aug 28 2026, 02:02 PM
Flyinlow
Hi.. I have a74 2.0 D Jet and I’m having a hesitation at throttle only have about2 hrs on motor after rebuild new fuel lines new MPs new fuel pump clean tank new correct CHT vacuum lines new and checked timing and dwell correct any suggestions appreciated. Dennis
emerygt350
post Aug 28 2026, 06:44 PM
Is this hesitation while revving the engine or when you are driving? Disconnect your TPS and see if it changes. These cars are surprisingly driveable without the TPS but it will have a pronounced hesitation.
Flyinlow
post Aug 29 2026, 09:40 AM
Flyinlow
QUOTE(emerygt350 @ Aug 28 2026, 05:44 PM) *
Driving I will check it out.. thanks!
yellowporky
post Aug 29 2026, 10:26 AM
I had a similar issue years ago and the TPs was the cause
Flyinlow
post Aug 29 2026, 06:16 PM
Flyinlow
QUOTE(yellowporky @ Aug 29 2026, 09:26 AM) *
Yup it’s probably the OG and won’t break the bank.. thanks
Flyinlow
post Sep 1 2026, 07:36 PM
Flyinlow
Yup parts ordered… thank you
- Lo-Fi Version Time is now: 15th September 2026 - 12:20 PM
