sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
come to the AX at teh stadium tomorrow. I'll have my V8 there and Im sure there will be various other teeners there.
bring hose clamps, vacuum line and carb cleaner. we can find teh vacuum leaks between run groups |
cbenitah |
Protected by the Swedish Maffia ![]() ![]() ![]() Group: Members Posts: 848 Joined: 16-August 05 From: San Diego, CA Member No.: 4,597 ![]() |
I was looking at that but you have to be a PCA member to go there right? I'm gonna sign up for that today I think.. What time is it at etc? I'm supposed to change my rear rotors and pads tomorrow, but i guess I'm over priced at that as well??? $200 for rotors + Pads |
cbenitah |
The clutch feels much more loose now though.. dunno how to explain it, but i dont need as much power to floor it as i had to before it poped.. But this issue was already there before the clutch poped! |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
OK, then I am a little stumped.
To check the clutch freeplay: Grab your clutch pedal and PULL TOWARDS YOU, you should have about 1/2" of pull, if more than that - clutch cable needs to be tightened, if there is no slack, your clutch is too tight. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
OMG. Do you know what a slipping clutch feels like? If not, get someone else to drive it for you and report.
And please, if it's not crystal clear yet, DON'T convert from FI to carbs. Glad you're here... please keep us posted before turning it over to your genious mechanic. |
cbenitah |
NOTHING, it feels like its as far back as possible... Can't move it at all, Clutch to tight? How can it feel like its more loose though when i press the pedel down... Do i adjust that at the Clutch Pull Piece? |
cbenitah |
No idea how a slipping clutch feels like.. maybe but not by the wording.. remember i have english as a second language (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) although i've been here for 3 years now.. But they dont teach you car terms in Beg. Eng... I guess I'm naive.. Its much easier to trust people in Sweden, so i guess i need to obtain the knowledge i need to not get F-ed over... Thanks for helping in everyway! I'm so glad I found this place! NOBEL PRICE to te founder (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Go to that a/x, sir.
No PCA membership to watch or run. free to watch I'm sure. take the help. KT |
cbenitah |
I want to.... Just need to know time.. Doesnt say on the PCA website.... |
TravisNeff |
Yes your clutch is too tight. Go under the car where the pulley is for the clutch cable, at the end of the cable there is the throwout arm, there at the arm you make your adjustments. Loosen up the double nut (or nylock nut) at the end of the cable. Go back and check your freeplay at the pedal. It is a little back and forth to get your 1/2" and then lock the double nuts down (tighten them against each other.
Lo-Fi Version | Time is now: 1st July 2024 - 05:36 AM |
