> suddenly only 0.2V to starter solenoid
gbp808
post Sep 10 2026, 05:50 PM
Hi All, just started working on a new-to-me 1975 914 2.0 rust bucket. Started by trying to start her up, had a good crank and brief start but carbs overflowing gas. Carbs rebuilt but now brief crank, then a few solenoid? clunks and now nothing. Only 0.2 v at the starter yellow wire (I did pull all the fuses since the wipers wouldn't stop and a lot of flashing dash lights). I know the eyes are rolling and I am going to be advised to check grounds, starter switch etc, but before I do that, is there something obvious I am missing? (seat belt interlock is spliced) Could I put 12V direct to the yellow lug to check the starter?
Thanks!
emerygt350
post Sep 10 2026, 05:53 PM
Yep, just make sure you are not under the tire.
If I remember right the fuse for the ignition is in the middle of the fuse bank.
emerygt350
post Sep 10 2026, 05:54 PM
Oh, and the ignition switch itself is notorious for breaking. Super easy to replace though.
Spoke
post Sep 11 2026, 01:11 PM
Jerry
QUOTE(gbp808 @ Sep 10 2026, 07:50 PM) *
I'm assuming a second person held the key in the START position while you measured the wire?
What is the voltage at the huge red wire on the starter?
You can jump the starter by removing the yellow wire and with another piece of wire connect to the spade on the bendix (where the wire was) and touch it to the huge red wire. Something should happen then. Make sure the car is in neutral.
Oh, also, (IMG:style_emoticons/default/welcome.png)
brant
post Sep 11 2026, 04:21 PM
The 75 and later switches are different at the ignition
My guess is the switch also
- Lo-Fi Version Time is now: 13th September 2026 - 05:14 AM
