> GoWesty 52 mm TB for L-Jet, linkage mod
rfinegan
post Sep 11 2026, 04:33 PM
I just got my 52 mm Tb from GoWesty for my 75 L-Jet conversions.
Question for those who have done this is what to do with the throttle linkage arm or throttle stop. I hear you just flip the linkage arm 180 degrees? Move the stop to the other side? Seems putting on the OE linkage would be even more trouble.... Please advise.
Best Regards
-Robert
rfinegan
post Sep 12 2026, 08:14 AM
The solution was right there.... I used the write up by VaccaRabite: http://www.914world.com/bbs2/index.php?sho...p;#entry2914136
I did not cut the New bracket to the 52 mm, I just needed to use the old OEM arm with the new one too.
Just take off the lock nut, hex nut and the washer off and add the the OEM arm to the assembly. Add the washer, nut and lock nut and you are done.
It the pics you can see the tail pip expander tool Used to pen the plenum to 53 mm and light rolled the edge to keep from digging into the gowesty gasket
rfinegan
post Sep 12 2026, 08:15 AM
next:
rfinegan
post Sep 12 2026, 08:16 AM
plenum:
rfinegan
post Sep 12 2026, 08:18 AM
Next add the Clewett TPS:
Root_Werks
post Sep 12 2026, 08:29 AM
Village Idiot
This is a pretty neat update to L-Jet. I should have done this to a 2.0 I installed L-Jet on years back.
StarBear
post Sep 12 2026, 11:07 AM
Wonder if it would work for a 1.8 LJet. Any advantages/disadvantages?
pfreiburger
post Sep 12 2026, 11:28 AM
QUOTE(StarBear @ Sep 12 2026, 12:07 PM) *
Nice work! Please report back on how much of a difference you can feel when driving.
JamesJ
post Sep 12 2026, 12:32 PM
QUOTE(rfinegan @ Sep 12 2026, 07:18 AM) *
These are available for 914-4s?
L-Jet914
post Sep 12 2026, 02:10 PM
I will say on the GoWesty website, it states that the throttle body was a drop in no adjustments needed. A friend of mine installed the throttle body on his Vanagon. I had to adjust the throttle stop screw so I could get the idle to drop to spec using the idle adjustment screw. So if you have an issue getting idle to drop to spec, adjust the little throttle stop screw.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: rfinegan
- Lo-Fi Version Time is now: 13th September 2026 - 05:14 AM
