| Rob-O |
Sep 29 2026, 11:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Hi All,
Ordered a new thermostat and parts from Awesome Powdercoat but still missing some items before I can get the thermostat one the car. I need #1, which is the bracket that holds the thermostat. Bought one from Awesome Powdercoat but it's all bent/smashed. I will contact him to see if he's got a better unit he can send as a replacement but in the meantime if someone has one. I need #5, which is a small bracket that helps hold/locate the end of the thermostat from twisting in the bracket. I need #20, which is a special shoulder bolt that holds the pulley to the block. Thanks! Attached thumbnail(s) |
| DC_neun_vierzehn |
Oct 4 2026, 04:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 682 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
@Rob-O
No affiliation to this seller, although I have purchased parts from them before and was a good experience … Looks like the shoulder bolt you need but be sure to verify: https://ebay.io/m/3xgnsp Looks like the small bracket you need: https://ebay.io/m/f7UhAK Looks like the main bracket you need: https://ebay.io/m/3xgnsp |
| bdstone914 |
Oct 4 2026, 06:32 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,415 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Rob-O
Pretty sure i have those parts and cansell them gor less than those ebay prices |
| bdstone914 |
Oct 4 2026, 10:28 AM
| bdstone914 |
Oct 12 2026, 01:51 AM
Lo-Fi Version | Time is now: 24th October 2026 - 01:58 PM |
