> Crank engine to build up oil pressure
burlybryan
post Oct 10 2026, 02:30 PM
I'm wrapping up installing my rebuilt 2 liter with djet. I want to crank it to circulate some oil without fuel. Can i just pull the fuel pump relay and turn on the ignition or will that disable more than the pump?
Thanks.
930cabman
post Oct 10 2026, 02:38 PM
I would also remove the spark plugs
emerygt350
post Oct 10 2026, 02:44 PM
Or you could pull the fuse on the board. It's the one closer to the rear of the car.
porschetub
post Oct 12 2026, 10:58 PM
QUOTE(burlybryan @ Oct 11 2026, 09:30 AM) *
Thanks.
Good idea after disconnecting the coil wires and pulling FP relay is to fit an oil pressure gauge and extention hose ,with plugs out and a good battery you should get quick suction and gauge climbing in pressure ,I got 72lbs total on my last topend build with new std rod bearing and good stock oil pump with 20/50 oil.
The gauge and line are cheap insurance afterall ,good luck ,cheers.
burlybryan
post Oct 13 2026, 08:23 AM
QUOTE(porschetub @ Oct 12 2026, 11:58 PM) *
Thanks.
Thanks. Stupid question - but what would I attach a hose to? It's a closed system, so there aren't any oil hoses to tap like a fuel pressure gauge. Maybe this is what to do on a 6?
In any event, fuse out, plugs out and no coil, wire it cranked well. Actually, it didn't turn over at all at first, but then I realized that I had one last remnant of DPO's conversion to carbs - they had cut and tapped the starter wire at the ignition for a separate power lead to the relay board. I had cleaned up the board end and returned to stock, but hadn't yet pulled the lower dash pad and chased the auxiliary wire. Removed and remade the starter wire connection and all is good.
Jack Standz
post Oct 13 2026, 09:40 AM
You could use an oil pressure test kit or gauge like this one:
https://www.harborfreight.com/engine-oil-pr...-kit-62621.html
You screw it into the case (with the correct threaded adapter) where the oil pressure sender goes which is by the distributor.
IronHillRestorations
post Oct 13 2026, 10:14 AM
I. I. R. C.
I’d pull the spark plugs and disable the fuel pump, and crank it in 15 second intervals until the oil pressure warning light goes out.
- Lo-Fi Version Time is now: 24th October 2026 - 01:59 PM
