| RKramden |
Oct 19 2026, 09:50 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California |
I think I know the general response, but I’ll ask anyway.
Putting a 3.0 performance built (premium pump gas) into the 914. No intention of racing. Maybe an auto cross or track night, or terrorize the neighborhood, but mostly C&C and PCA events. No heat exchangers ( So.Cal), an oversized oil tank in the engine bay, and a 916-6 type engine lid. In lieu of a remote oil cooler I was considering changing the fresh air fan piping to blow back through the heater longs up through the tins and outlet right next to the engine cooling fan inlet space. Or possibly just blow on either side of motor below the tins. I’m wondering if this has ever been done successfully or if the idea makes any sense at all? Any thoughts or suggestions would be appreciated |
| brant |
Oct 19 2026, 10:04 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,297 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The heater fan is really an insignificant amount of air
The -6 engine fan is likely 10x the amount of air already I don’t think it will help to any noticeable amount If the car/engine runs cool (low rpm) you may be fine without an aux cooler. If the oil runs warm you won’t. Some do. Usually depends on the amount of wear the motor already has or how it’s used-rpm |
| mepstein |
Oct 19 2026, 10:06 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,015 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The fresh air fan hardly moves any air in the cabin. It's not going to do anything to cool the engine.
Are you ever going to be going up a hill on a hot day? Stopped at a light for a while or stuck in a traffic jam on the road with the asphalt radiating heat up into the car. |
| Superhawk996 |
Oct 19 2026, 12:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,189 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
(IMG:style_emoticons/default/agree.gif) both the above are correct
You cannot offset oil cooling with more air cooling. The primary reason being the heat transfer coefficient of air is (IMG:style_emoticons/default/stromberg.gif) compared to oil. Oil cooling is about 10x more efficient than air cooling. This is why the 911 engine has an oil cooler in the first place and why all the S performance variants ran an aux cooler in addition to the engine mounted oil cooler. Though the engine is called air cooled, it is heavily cooled by oil in addition to the cooling done by fan. |
| IronHillRestorations |
Oct 20 2026, 07:29 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
You won’t get enough airflow from the fresh air blower to help.
You might consider adding an oil cooler like this: Rear fender oil cooler |
| mepstein |
Oct 20 2026, 09:58 AM
Do the conversion, drive it. If it needs more cooling, figure out the best way to accomplish it with your budget and goals. You probably will need additional cooling but it’s not a sure bet. Some engines run cooler than others.
Sometimes it’s better to have a running car that needs mods that a project car that doesn’t move. |
| Superhawk996 |
Oct 20 2026, 10:42 AM
Sometimes it’s better to have a running car that needs mods that a project car that doesn’t move. That’s some real wisdom there and didn’t cost you a dime. (IMG:style_emoticons/default/aktion035.gif) |
| pete-stevers |
Oct 20 2026, 02:39 PM
Shinee Side Up ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest
My recommendation split for the external cooler up front with a Mocal 180 degree thermostat... Eric Shea has a great system... How much is that 3.0 worth? sometime you just have to split for it! (IMG:style_emoticons/default/biggrin.gif)
| JmuRiz |
Oct 20 2026, 02:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,655 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Sometimes it’s better to have a running car that needs mods that a project car that doesn’t move. (IMG:style_emoticons/default/idea.gif) I resemble that remark (IMG:style_emoticons/default/wacko.gif) |
| Cairo94507 |
Oct 20 2026, 03:52 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,802 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
A 3.0 in southern CA is likely going to need an external oil cooler to be able to drive worry free in the summer or while sitting in stop/go traffic on the freeway. It's a bit of work but does not have to be overly complicated. Lots of threads here with different solutions that work. Good luck and enjoy the 3.0. (IMG:style_emoticons/default/beerchug.gif)
| mb911 |
Oct 20 2026, 07:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,855 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Build it first get it running add a cooler in the non driving season if needed. Do you guys in Cali have a non driving season? We are forced to here
| Steve |
Oct 21 2026, 08:00 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,132 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Build it first get it running add a cooler in the non driving season if needed. Do you guys in Cali have a non driving season? We are forced to here Not really.. It doesn't rain enough to have an off season. Just a couple seasons when you don't need AC. I agree with others, So Cal is very toasty in the summer and this will need an external oil cooler during that time. You might get a way with a cooler and fan next to the trans. The 3.0 and 3.2 run much cooler than the smaller magnesium motors. |
| RKramden |
Oct 22 2026, 07:07 PM
Thank you all for your inputs. Ill be adding a remote cooler. Any thoughts on the oil tank size? Will the oversized PMB in fender model be enough or do I need more capacity?
| mepstein |
Oct 22 2026, 07:25 PM
Oil tank - Definitely Ben’s/MB911/914-6Werkshop.com
Total capacity with a cooler is about 11 quarts. |
| RKramden |
Nov 2 2026, 05:47 PM
Based on my usage noted at the beginning of this thread, is there a need for a “catch can” in this system?
| 930cabman |
Nov 2 2026, 05:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,888 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| mb911 |
Nov 3 2026, 08:34 PM
| worn |
Nov 3 2026, 11:30 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,666 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Sometimes it’s better to have a running car that needs mods that a project car that doesn’t move. (IMG:style_emoticons/default/idea.gif) I resemble that remark (IMG:style_emoticons/default/wacko.gif) Well, we all, or many of us do. I run a heat exchanger in the space behind the right axle. Have run the 3.2 in 100 degree weather on the 80 mph interstate without trouble. Haven’t tried stop and go under those conditions and hope not to. |
Lo-Fi Version | Time is now: 24th November 2026 - 10:03 AM |
