| Robarabian |
Oct 24 2026, 07:26 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 745 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
For sale is an original 914-6 Oil tank in great shape. As you can see, the black paint is coming off as I cleaned it up a bit. The copper coating is very intact, no outside corrosion. Inside, it is very clean. This came off my running car before I put one of Ben's aluminum tanks in it, as it is not a factory six car but is a conversion car. Included is AN oil fill tube with dipstick and the filter console as pictured. BONUS: The oil lines you see are included and are in good shape, but I also have the beautifully zinc coated oil line connections for you to make your own factory lines if you choose. I will include at least 2 oil filters (maybe 3 Mahle, WIX and Mann I believe).
Note: I am not an expert expert and if there is some marking I need to look for or photograph for the buyer, please let me know. This car was converted many years ago by another World member and that original listing I had found listed it as an original tank. AS NOTED IN THE COMMENTS: The Filler neck appears to be a 911 part, not a 914-6 part, but it worked as set up installed on the car. Shipping is CONUS and at actual cost. I am asking $1600.00 as this is all complete, ready to bolt in and has amazing spare parts to go with it. In Southern California. ![]() |
| mb911 |
Oct 26 2026, 05:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,824 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Good luck with the sale. Pretty complete kit
| sixnotfour |
Oct 26 2026, 06:58 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,399 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| Robarabian |
Oct 26 2026, 08:24 AM
| Luke M |
Oct 26 2026, 08:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
If you're willing to split the fittings from the whole bunch I'd be interested in them.
Let me know. |
| Robarabian |
Oct 26 2026, 08:29 AM
If you're willing to split the fittings from the whole bunch I'd be interested in them. Let me know. Hi Luke, let's see how it pans out a bit. Maybe someone wants the tank and lines and not the fittings. These cars require constant fundraising to keep em going so ill give you a "Magic 8 Ball" type answer, "signs point to yes..." |
Lo-Fi Version | Time is now: 26th October 2026 - 10:52 AM |
