> AAR and leaks, Outsmarted myself
ctc911ctc
post Nov 1 2026, 07:10 PM
'74 914-2L, 22Kmiles
There are many threads about this car - parked in 84, resurrected in 2017 by me.
Hell hole was bad, trussed and patched by my 16year old at the time.
Holes in the Plenum - welded and smoke tested under pressure - perfect.
Throttle body was leaky, sent it to a guy in this forum - sent me a different one that was rebuilt - seems ok,
the AAR was not closing all of the way - I cleaned and had it working a few years ago, it is not fully closing, idles at 1100 with the adjustment screw all of the way in.
HHHHhhhhhmmmmm, thought I had it working OK......hhhmmm
If I place my thumb over the inlet hose to the AAR, i can get to 900 with the throttle screw all the way in.
Question
Has anyone changed the holes size in the throttle plate to manage this issue?
Yes the plate seats well in the throttle body......springs pull it shut - completely,
CTC911CTC
JamesM
post Nov 1 2026, 08:11 PM
QUOTE(ctc911ctc @ Nov 1 2026, 05:10 PM) *
Question
CTC911CTC
Dont do it, the throttle plate is not your problem.
Most likely are not getting proper timing retard from the distributor at idle.
ctc911ctc
post Nov 1 2026, 09:08 PM
So, check timing at idle?
QUOTE(JamesM @ Nov 1 2026, 09:11 PM) *
Question
CTC911CTC
StarBear
post Nov 2 2026, 07:49 AM
Also, check to ensure you have the correct AAR. There are small differences that make big differences. AMHIK….. (IMG:style_emoticons/default/dry.gif)
emerygt350
post Nov 2 2026, 08:01 AM
It sounds like your AAR is still not closing all the way, that is what you imply by putting your thumb over the AAR inlet hose.
I think the problem you will have with 'fudging it' is going to be different behavior as the engine gets hot.
Of course the best thing to do is get a different AAR (good luck).
You could put a valve like mine inline with the AAR and just close it after the first warm up of the day. Sometimes I do that during the winter because mine is sluggish and stays open too long in cold weather. Isnt' really a problem after the car gets hot once during a day. Mostly I use the valve for troubleshooting (to see if the AAR is closed yet when dealing with stuff like you are experiencing).
I wouldn't use timing to lower the idle at this point, because you would have to lower the timing overall to get that to work with the retard and nobody wants that.
Also, in cool weather I notice that the car's ecu continues to create a rich condition that brings the idle up to almost 1100 on my car for longer than I think is necessary. I suspect this is from the other temp gauge that sits in the plenum working as a charge temp sensor. But if your thumb on the aar reduces idle that is not yet your issue.
JamesM
post Nov 3 2026, 02:43 PM
QUOTE(ctc911ctc @ Nov 1 2026, 07:08 PM) *
This assumes your AAR is 100% closed. If putting your thumb over it fixes is, your AAR is the problem.
Also assuming your timing is set properly at 3000 rpm, the timing you get at idle is dictated by your engine vacuum and distributor functioning properly.
The proper fix in either case is parts that are not bad.
JamesM
post Nov 3 2026, 02:47 PM
QUOTE(emerygt350 @ Nov 2 2026, 06:01 AM) *
Good Luck indeed
I have 5 on my workbench in my garage right now. While I have cleared the movement off all 5, 4 of them have electrical continuity issues.
Last one I attempted to open to repair did not go well. They sit on my workbench as a reminder to think about the problem.
- Lo-Fi Version Time is now: 11th November 2026 - 06:06 AM
