> PMO owners, Enlighten me please.
Shivers
post Nov 2 2026, 03:20 PM
PMO fuel pressure regulator. With the barbed nipples it is 8mm for all of them including the one for the stock size 9.5mm supply line. The AN6 fittings are 9.5. How did you get around this? This one has 8mm supply feeding two 8mm nipples to the carbs. Am I missing something, do they all need to be one size? I ve been all over town trying to find a 9.5 barbed fitting with no luck. I’d call PMO but I could only find a fax number. A little help would be great. Thanks
friethmiller
post Nov 2 2026, 04:18 PM
QUOTE(Shivers @ Nov 2 2026, 03:20 PM) *
Yeah Shivers... I just hit this problem a few days ago. I have the same set up. In a pinch, I bought a male to male 3/8" barbed union and reduced the hose to a 5/16" just before the inlet side of my PMO regulator. This seemed to work and it certainly eliminated the leak I had when using the 3/8" hose directly. If the inlet barb could be increased in size, that would be the better solution for sure.
From what I understand, 5/16" = 8mm and 3/8" = 9.5mm
UPDATE: Amazon has the correct unions for a better reduction. Perhaps the inlet can be had as well. What's the threaded size of the inlet barb fitting?
friethmiller
post Nov 2 2026, 04:43 PM
BTW, I figured out what PMO stands for .... Leaky Gas Box! Make sure all those fittings are tight.
Shivers
post Nov 2 2026, 05:18 PM
QUOTE(friethmiller @ Nov 2 2026, 02:18 PM) *
I was actually hoping someone here would know It's not pipe thread, I think it is metric but otherwise I'm clueless. Thanks for the leak tip. I have some good pipe dope for the threads
infraredcalvin
post Nov 2 2026, 10:14 PM
Distracted Member
They make that part with AN fittings… I’d bet you can remove the barb fitting and fit a proper AN sized to your liking…
frank_c
post Nov 3 2026, 12:13 AM
QUOTE(infraredcalvin @ Nov 2 2026, 11:14 PM) *
I went the AN route. No leaks after ~12 years (knock on wood).
Shivers
post Nov 3 2026, 03:26 AM
QUOTE(friethmiller @ Nov 2 2026, 02:43 PM) *
I ordered one of these, I hope it fits. I ID’d the threads the best I could. It will be here tomorrow, I’ll let you know if it will work.
Shivers
post Nov 11 2026, 07:35 AM
The fitting is M12X1.25 not 1.5. So close I was getting excited till it was threaded a 1/3 of the way in then “Bummer!” . So I looked for what seemed longer than I should have for this one. Link below. It does not have a big shoulder for the washer. Instead it has a small shoulder. But I will make a copper washer that will thread on and use a thread sealer to make sure. I could have purchased the regulator with AN fittings but all the rest to install cost a small fortune. My fortune is weak, more like flaccid, so I need to make this work since the rest is already on the car.
M12x1.25 fitting
friethmiller
post Nov 11 2026, 08:43 AM
Same. I just received a set of 10mm to M12X1.25 and 8mm to M12X1.25. But the 8mm weren't correct. The thread pitch wasn't right. Luckily the 10mm, which is the one I really needed, worked great! I still want to replace the other 8mm fittings because I want a better barbed end. Definitely used/using thread sealant on these.
Shivers
post Nov 11 2026, 09:52 AM
QUOTE(friethmiller @ Nov 11 2026, 06:43 AM) *
Oh that is great…Rock on Fred
friethmiller
post Nov 15 2026, 02:52 PM
Just to follow up. I reordered the 8mm inlets. This time the thread pitch (M12x1.25) was correct. Here's a pic of everything switched out and the thread sealant I used. I'm going with the original rubber washers for now. If it still leaks, I'll switch to brass.
rgalla9146
post Nov 17 2026, 06:57 AM
Banjos
Will drill for safety wire.
Will re-do mounting plate with proper starter button.
Might add hose clamps.
2 litre beverage bottle repurposed as catch can....needs cleaning
Blue cap for weather protection.
friethmiller
post Nov 17 2026, 07:25 AM
QUOTE(rgalla9146 @ Nov 17 2026, 06:57 AM) *
Banjos
Will re-do mounting plate with starter button.
and maybe add hose clamps
Nice! That's a lot like mine. Can you post a pic of the 90 degree fitting for the psi gauge? Mine is very hard to read as the mounting plate prevents it swiveling to a point where I can read it from the side of the engine bay. Cutting a hole in the mount [like yours] might allow for enough room and still keep the gauge vertical. (IMG:style_emoticons/default/idea.gif) TIA.
Don't mean to hijack your thread @Shivers but it's interesting to see what others have done to mount/install their regulators.
rgalla9146
post Nov 17 2026, 01:49 PM
QUOTE(friethmiller @ Nov 17 2026, 08:25 AM) *
Banjos
Here you go
and the build too
http://www.914world.com/bbs2/index.php?showtopic=310032
Shivers
post Nov 17 2026, 01:56 PM
QUOTE(rgalla9146 @ Nov 17 2026, 11:49 AM) *
Banjos
Here you go
Glad you did, I’ll be hunting down a 90.
friethmiller
post Nov 17 2026, 02:21 PM
QUOTE(rgalla9146 @ Nov 17 2026, 01:49 PM) *
Great build, BTW. I really liked your modification to the rear control arms and the fabrication in the front trunk. First class! (IMG:style_emoticons/default/first.gif)
rgalla9146
post Nov 17 2026, 03:53 PM
QUOTE(Shivers @ Nov 17 2026, 02:56 PM) *
Banjos
Here you go
Brass fittings are stupid expensive now.
Might need a mortgage (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 24th November 2026 - 02:12 PM
