> I should know this., Does a Type IV bolt up to the transaxle in a 68 912?
rick 918-S
post Nov 10 2026, 07:04 AM
Hey nice rack! -Celette
And is that box a 5 sp? Zero experience with the early 912's
post Nov 10 2026, 07:08 AM
914-6 GT in waiting
Yes
rick 918-S
post Nov 10 2026, 07:51 AM
QUOTE(mepstein @ Nov 10 2026, 07:08 AM) *
Yes
Thanks, Although I had a 356 I never pulled a 365 style engine. Any issues with the clutch/pressure plate selection?
RRietman
post Nov 10 2026, 08:04 AM
QUOTE(rick 918-S @ Nov 10 2026, 05:51 AM) *
Yes
I ran a type 4 engine in my 68 912 for 15 years, worked great. use a 914 flywheel and an early 911 clutch set up. some will say that you must change the gearing in the 912 trans to get the engine to stay on the pipe but I was satisfied with leaving it stock. fair amount of fabrication involved with the install, motor mount, engine tin, wiring,etc.
good luck
Randy
rick 918-S
post Nov 10 2026, 09:20 AM
QUOTE(RRietman @ Nov 10 2026, 08:04 AM) *
Yes
good luck
Randy
Thanks Randy. I was fortunate to get some 912E tin several years ago and a mount that I think will bolt in. Just finally getting around to looking at this car again. I have a set of 911 Thermo head cracker heat exchangers and a 911 muffler I am going to try to use. I will need to build a custom set of headers to connect to the HE. I heard the muffler may not fit between the rear fo the car and the engine... (IMG:style_emoticons/default/idea.gif) We shall see.
Krieger
post Nov 10 2026, 09:37 AM
I saw these 912e heat exchangers are for sale on Pelican the other day. It may be easier and bolt right up. https://forums.pelicanparts.com/porsche-911...o-reactors.html.
Ditch the thermal reactors or gut them. Busch made replacement pipes for the thermal reactor and muffler.
Root_Werks
post Nov 10 2026, 11:42 AM
Village Idiot
Eek, 912 HE's have gotten spendy.
rick 918-S
post Nov 10 2026, 11:56 AM
QUOTE(Krieger @ Nov 10 2026, 09:37 AM) *
Thanks for the link. Those are spendy. I bought the 911 ones for like $ 100.00. they look pretty much the same.
sixnotfour
post Nov 10 2026, 05:23 PM
@914Werke
Rich had some 912 stuff..
914werke
post Nov 10 2026, 07:19 PM
Depends on the trans. installed 901 yes 923 yes 915 no
RRietman
post Nov 11 2026, 09:24 AM
QUOTE(rick 918-S @ Nov 10 2026, 09:56 AM) *
I used VW 411 heat exchangers in the 912. just bolt up a 914 extractor and you are good to go. there is probably some bus stuff that could work as well.
Randy
- Lo-Fi Version Time is now: 24th November 2026 - 02:12 PM
