> 914World Classifieds Rules
> WTB: lower engine tin /air guide - passenger side and used pair of rear shocks and springs for 75 1.8, Could also use Thermostat, bracket, cable, wheel, flap w rod, etc.
914rrr
post Nov 11 2026, 11:54 AM
Seeking lower engine tin / air guide on the passenger side and a pair of rear shocks w springs for my 75 1.8.
I could also use a thermostat, bracket, cable, wheel, driver side flap w rod, bushings, etc. assembly for same. I can possibly pick these up as I commute weekly from McMinnville, TN to Cincy / N. KY areas. ex: I drive through Louisville or Lexington KY or can detour through Knoxville, Nashville, etc.
914werke
post Nov 11 2026, 05:30 PM
Do you mean the under cylinder tin or the air deflector for that side?
914rrr
post Nov 11 2026, 08:38 PM
QUOTE(914werke @ Nov 11 2026, 06:30 PM) *
I believe I'm asking for the air deflector / air guide plate, 75-76.
GaroldShaffer
post Nov 11 2026, 09:51 PM
You bought another 914?
I have these. Obviously they need cleaned up and painted. Thermostat tested and works .pictures shows cold and heated up with heat gun. Will need to swap the cable with the spare in the pictures. I dont have a good wheel. Let me know if you are interested.
GaroldShaffer
post Nov 12 2026, 06:57 AM
Is this the tin you need?
914rrr
post Nov 12 2026, 07:20 AM
QUOTE(GaroldShaffer @ Nov 12 2026, 07:57 AM) *
I'm not sure, I think that's the driver's side. Definitely interested in the thermostat and parts.
GaroldShaffer
post Nov 12 2026, 07:58 AM
QUOTE(914rrr @ Nov 12 2026, 07:20 AM) *
Pm sent
malcolm2
post Nov 13 2026, 06:55 AM
Awesome powdercoat dot com has new t-stats etc…
- Lo-Fi Version Time is now: 24th November 2026 - 02:12 PM
