> Spacer in between deck lid pull handle and pull handle base
L-Jet914
post Nov 11 2026, 08:04 PM
I was wondering if any of the parts suppliers remake the spacer (part# 2) between the engine deck lid pull handle and handle base. I replaced both of mine a number of years ago and something looked out of place as there is a significant gap between the pull handle knob and base. I was looking at the FSM and saw that there is supposed to be a spacer in between the two. I think my spacer deteriorated or fell into pieces when I went to replace the pull knob and base it's been too long.
aturboman
post Nov 12 2026, 03:27 PM
Its a soft rubber part. I'm sure its to eliminate the hard plastic parts from rubbing and making a seal to avoid water or other no no's from entering through the engine compartment.
Porsche still had stock last time I checked.
Nogoodwithusernames
post Nov 12 2026, 06:02 PM
If nobody currently makes them let me know and I could 3D print a batch out of black TPU at work if people wanted to get together for a group buy. Probably $5 per part depending on how many people get involved, and it's thin enough of a part it should fit in a regular envelope so shipping would only be $0.76.
L-Jet914
post Nov 12 2026, 08:07 PM
QUOTE(aturboman @ Nov 12 2026, 01:27 PM) *
Would you happen to know the part number because the PET doesn't list it or show it in the parts explosions.Edit: I think I found it. 911-511-332-00 (see pic). Looks like EPDM rubber?
NARP74
post Nov 12 2026, 09:00 PM
I hate when this happens. Now I have to go look!
RoadGlue
post Nov 12 2026, 10:24 PM
Sonoma County Gear Head
L-Jet914
post Nov 12 2026, 10:49 PM
Yup even my hard copies that I recently purchased from a member here only show the pull handle and retaining bushing.
JeffBowlsby
post Nov 12 2026, 11:17 PM
Note item 3: in the diagram above. It’s a rubber cap that the cable passes through. Keeps the water out of the tube.
L-Jet914
post Nov 12 2026, 11:32 PM
Which diagram are you referencing to @JeffBowlsby for item 3? Or do you mean 33? I was looking for the part number in my initial post which is not listed in the 914 PET paperback or electronic. I also think I found what @aturboman mentioned as a 911 part number.
DennisV
post Nov 13 2026, 09:05 AM
QUOTE(L-Jet914 @ Nov 11 2026, 06:04 PM) *
Thanks for brining this up. I saw George @dr914 reference this part in his recent interior video, and I started looking for it as well. I was hoping he'd reply to the comment in YouTube. Our car didn't have the spacer or the main bushing. Someone had used the bezel from a radio antenna behind the pull knob. (IMG:style_emoticons/default/confused24.gif)
JeffBowlsby
post Nov 13 2026, 10:17 AM
QUOTE(JeffBowlsby @ Nov 12 2026, 09:17 PM) *
Sorry, 33 is correct. My fat fingers....
L-Jet914
post Nov 13 2026, 09:21 PM
QUOTE(DennisV @ Nov 13 2026, 07:05 AM) *
You're welcome.
I just watched the video. I see where he mentioned the little buffer but makes no mention of AA supplying replacements.
DennisV
post Nov 14 2026, 07:06 AM
QUOTE(L-Jet914 @ Nov 13 2026, 07:21 PM) *
You're welcome.
Doesn't sound like they have, or are planning, to offer it. A quote from George in another thread:
QUOTE(dr914@autoatlanta.com @ Nov 13 2026, 09:11 AM) *
the rubber buffer is one of those parts that they forgot to put in the parts boot, but it is a small rubber washer, something like one would use for a faucet
Does anyone have an original they can supply dimensions from?
rudedude
post Nov 14 2026, 07:23 AM
If I had to guess I would say it is the same rubber washer that is on my 70 911 rear deck release. Part #90151179121. I’m not at home to measure until tomorrow if you would like. They sure look the same to me when I have looked at them.
DennisV
post Nov 14 2026, 08:42 AM
QUOTE(rudedude @ Nov 14 2026, 05:23 AM) *
Good call. This part is shown in the 1965-69 911 parts catalog for use on the front and rear lid release cables too.
L-Jet914
post Nov 14 2026, 05:37 PM
(IMG:style_emoticons/default/beerchug.gif) I second DennisV's response. Now to go out and purchase a few.
aturboman
post Nov 14 2026, 06:14 PM
Confirmed part number is 901 511 791 21.
Porsche still sells it $6
- Lo-Fi Version Time is now: 24th November 2026 - 02:12 PM
