| frank_c |
Nov 11 2026, 11:58 PM
Member ![]() ![]() Group: Members Posts: 125 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
I have a bit of a strange question. I recently removed the (I assume, original) 914 Boge struts from my '76 to install 911 struts (5-lug conversion), and noticed that the housing tubes have a 10mm hole at the bottom - right above the ball joint post (see photo). Is this normal? The Boge 911 struts don't have this (nor do my Koni or Bilstein strut housings IIRC).
I read that some early Koni inserts used a stud at the bottom to hold the insert in place, and that a hole would need to be drilled in a Boge strut if using one of these early Konis, but that seems unlikely (btw, the 914 had KYB inserts in it when I got it). I'm asking because I plan to post these for sale soon, and was wondering if this is something I need to mention in the ad. Thanks, Frank |
| bdstone914 |
Nov 12 2026, 03:10 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,430 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| Krieger |
Nov 12 2026, 10:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,902 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Early boge strut housings had no hole in the bottom. No hole necessary for koni inserts in boge struts. Koni struts only fit koni shock inserts
| frank_c |
Nov 13 2026, 12:02 AM
Ok, thanks - good to know that it "belongs" there.
Does anyone know its purpose? That is, why was the hole was added for the later Boge housing? Perhaps to allow any condensation to drip out? Not that the water could go very far as the ball joint post is directly below it. |
Lo-Fi Version | Time is now: 24th November 2026 - 02:12 PM |
