SS Fuel Line Installation, with pictures |
smooth_eddy |
Sep 16 2005, 04:57 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
From your last picture it looks like you used 2 different types of hose under the gas tank. What was the reason? Also, from an old post the ends of the metal fuel line was threaded so the hose gets a good bite. Do you think there is any chance of your connections coming apart? This is my next project. I am glad it can be done with the engine in place. How long did it take including removing and replacing the interior? Thanks, Eddy
billd |
Sep 16 2005, 06:44 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
The lines out of the fuel tank are two very different sizes, so I used different size hose. I used 9mm hose on the line from the tank to the fuel filter, 7mm hose from the return line to the tank. I chose to use 5/16 hose on the line from the pump to the tank. 9mm would have worked as well, but 5/16 was a more snug fit on the 5/16 OD SS line. To get the hoses to grip on the SS line I notched the SS line with a file and die grinder. About four notches, one every 1/4 inch at about four places around the circumference of the tube. I also degreased the lines with solvent to get them real clean before I slipped the hoses on. I'll keep an eye on them, but I don't think the hoses will come off. I did this project over a period of several weeks, grabbing an hour here or there as time allowed. A rough guess on time is: Remove fuel tank, interior, and old lines - 1 hour. Fit new lines in place - this took me about 3 hours, but if you ended the lines at the right side of the firewall I think you could do it in 1 to 1.5 hours. Clamp new lines to firewall - 0.5 hour. Fabricate clamp and clamp lines under tank - this took me about 1 hour, but you could omit this step. Reinstall fuel tank - 0.5 hours. Reinstall interior - I haven't done this yet. I'll guess 1.5 hours. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:44 PM |
