kdfoust |
Senior Member ![]() ![]() ![]() Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California ![]() |
Yeah, good point on the thick flanges and spacers. Those go on the list. Kevin |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
i ended up mushing that part of the pulley into itself. It looks really good like it was design that way. Sorry no pics of it though. Kind of hard to take a pic of it right now, being installed. |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Yup. My copy of the 914-6 sheet metal was too close to the AC pulley to get a belt through there, but everything did clear. I ended up cutting the AC pulley off and turning the rest down on my lathe. I was just curious as to how close I came with my home made sheet metal. It sounds like I was pretty close. (Nearly completed sheet metal) Attached image(s) ![]() |
kdfoust |
The clock is ticking. November is coming on quick. I want to be driving this puppy in November! (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
I've got a driving school this Saturday and a business trip starting Sunday that'll take out a whole swath of wrench time. Then even worse yet I'm off to Willow Springs for the last POC STS weekend of the year the first weekend of November. I'm going to be down from wrenching for 7 days coming soon. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) So I continue to work consistently on the project... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) I've completed the engine compartment wiring and the wiring in the passenger compartment. I ran a big a**ed 4 gauge cable from the starter to the front trunk for the new battery location. I've got a -6 tach and a new combo gauge with oil pressure and temp. The oil cooler is out having a -16AN fitting welded on. Tomorrow I order the Getty oil cooler shroud. Tonight I was sorting out the location for the various oil system components in the front trunk. I was on the fence about the Odyssey Battery but I've made up my mind. I'm putting the Odyssey in because it fits so much better than the old battery with the layout. Check out the four basic locations I went through for the major pieces. You have to picture the Getty Design oil cooler shroud in place in the center of the trunk as well. The Odyssey Battery is so thin (3.1") that I could mount it on top of the oil cooler shroud if I want. Option 4 is my choice. The white box represents the Odyssey battery. The red wire laying on the floor of the trunk is from the front trunk mount fuel pump relo. It looks like I'm gonna miss the first weekend of November for the first drive and I'm disappointed by that. But driving is my "thing" the whole reason for building this insane little car so there's no way I'm missing the school or the POC weekend. Later, Kevin Attached image(s) ![]() |
John |
I like option 1. It keeps the majority of weight closer to the front axle instead of moving it even further forward. It's laid out similar to our track car.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
The great things about the Oddessey battery is that it's small and light....you can put it about anywhere. There is no "Where do I put 38lbs" thing as it weighs 13 lbs.I put mine here.
I was able to use a single strap as there is an upset formed into the trunk floor in just the right spot.that keeps it from sliding sideways. This also makes for short wire runs...less weight, less resistance. Attached thumbnail(s) ![]() |
kdfoust |
Hey JP, so you're spinning a 2.7 with the Odyssey. What the heck is that thing on the left side of your trunk?
I did a quick run through the weight distribution on the car making some assumptions like the car wieghed 2100# originally and was 48/52 wt dist. By adding the 3.2 the distribution shifts from 48FR/52RR to 46FR/54RR. With a heavy battery (38#) located in the front trunk and all the other oil stuff I estimated the weight distribution to be at 47.5/52.5. So part of my motive was to keep the car as close to balanced as I could. Not that it matters all that much, since I'll sorting ot the suspension all over again anyway. But, It's not supposed to be a taildragger... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Later, Kevin PS Do you guys think the ducktape will get through tech inspection? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
Oil 1:
Series9 |
Oil 2:
kdfoust |
Hey Joe. That's one heck of an oil cooler. So I reckon that fan is pushing air out of the trunk? I notice that you've got the oil filter in front. Why did you make that choice? I was planning to put it on the engine compartment firewall low and on the driver's side like this PMS conversion car's. I guess I hadn't given the filter location a lot of thought... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Later, Kevin |
Series9 |
It doesn't matter where you put the filter. Just somewhere in the scavenge line. The 3.6 has an on-engine filter too (stock), which replaces the on-engine oil cooler. Hence the size of the front cooler. |
J P Stein |
A puke botttle.....the hose from the tank was not hooked up at that time. Inside is a breather/filter. I've seen too many breathers exposed in compartments....engine and trunk.... that were saturated with oil and were then doing an oil down on the whole area. I puke out 4-8 ozs of oil at a typical AX. The lid of the mixed nuts bottle is vented but with a foam insert under the lid to knock down more vapor. On the street & track, it stayed dry, so it is prolly overkill if that is all you're going to do. I've theroized that AX gets the oil in the tank sloshing (it gets me sloshing:D ) around and it then gets caught up in the airflow of 6/7K rpm windage. That Odyssey has given me no troubles. It cranks the motor over well.....my car sits up to a month between starts. When it sits for more than a week, I spin it over for 30-50 sec to pump some of the oil out of the sump & into the tank before trying to start it. It seems to be kept charged by AXing only.....surprised me. I think the short lines help. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) 50-50% weight would be nice, but I gave up worring about that in the pursuit of lightness......and it's easy to take weight off the front so it comes from there or nowhere. I put a 5 gal gas tank on the floor where you have the oil tank...weight up high is bad, too. I'm thinking of taking 30 or so pounds off the top of my cage.....but putting it back in below dash level. |
J P Stein |
My thinking on the locations of the various oil system locations is to pump unregulated cold oil the least distance possible.
When I was doing front cooler, I talked (email) with a racer that had rigged a pressure gauge on the scavenge side. He said be had seen 165 psi during cold starts. My cooler was supposedly good to 300psi.....before it blew on a cold start. The Thermostat was plumbed wrong....feeding cold oil to it and "other stuff".....not my finest moment (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) If you ever get to fool with a 911 oil pump, you'll see what an efficient little bastard it is. It looks like a tenth scale 6-71 blower. |
kdfoust |
Yesterday I was at an Evolution AX driving school in Fontucky (Fontana). I took the "other Porsche." While it's a fun car we all know that the 14 is the tool for AX. Part of the course had a seven cone slalom that would have been taken WFO in the 1.7 version of the 914. With the 3.2 version I'm sure that I'd have to do some pedalling to keep everything hooked up. The "other Porsche" needed some pedalling...
I've been working on the oil system. I finally found a location for the filter that makes me happy. I've got those worthless -4 engine mount brackets on the frame doing absolutly nothing now with the -6 installed. I'm mounting the oil filter inside of u-shaped bracket that is the -4 engine mount. The firewall mount was just in the way of too many things, including the proportioning valve, the e-brake cabling, and the heater hose. I'll have to fabricate a mounting bracket for the filter housing and weld that bracket to the engine mount dingus. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) I was sizing up the oil cooler opening and exit ports as well as looking over the Getty -6GT oil cooler shroud. The cover part of the Getty is pretty obvious as to the fit in the car, however, the 2nd part is a little less obvious. It really doesn't seem to fit my car well at all. Remembering that I've got an early car ('72) I'm a little puzzled by the shape and fit of 2nd part. Anybody got any experience with this setup and some pictures that show the two pieces and how they're mounted together. Here's my guess. It looks like I need to do a little glass work to fill in gaps and such... Later, Kevin Attached image(s) ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Here's a picture that shows where the second piece goes.
It just lays on the trunk floor between the front and rear cutout. Its easy to figure out the cutouts by just laying this piece in the trunk. I first put in the big part that covers the oil cooler and used a permanent black marker to draw around it. I then took out the big part and laid the smaler part in the trunk floor. Its pretty obvious where you need to cut by comparing the black marker to where the second piece is laying. The second part is used to guide the air out the back opening. These pictures are from a real six being converted to a GT. So they should be the same as your car. Attached thumbnail(s) ![]() |
Steve |
Here's a picture without the piece in place.
Steve |
Another good picture without the parts in place.
Steve |
Here's a shot from the front.
kdfoust |
Ohhhh. The bottom piece actually extends forward to meet the cutout in the valance? Wow, that's not I pictured at all. I hadn't planned to slot all that out, I was just going to use the existing holes in the body work.
Kevin |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Joe (914RS), Nice looking work in the front trunk. I noticed that you don't have a rubber weather strip in the front lid channel. With your fan arranged to exhaust air from the trunk, creating a low pressure area in the trunk, and through the oil cooler, I wonder how much air is being drawn from around the hood. If you ever have a temperature problem you might consider some type of weather strip for the channel to seal off this air and restrict air flow to the coooler only. That looks like a pretty good sized cooler so this may not be a problem. Just a thought. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 05:30 PM |
