boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Hey all. I am so geeked about my *new* 914 that arrived today. 1970 1.7L Adriatic Blue. (IMG:style_emoticons/default/boldblue.gif)
Although I know it can cost tons of money to restore a 914, I am seriously commited to it. I realize that I could sink $20,000 into this car and not even be able to sell it for 1/2 of that in 4-5 years. Money is an object, but I am *wealthy* to a degree and can afford it. Heck, we all know you can't take the money with you anyways. (IMG:style_emoticons/default/cool.gif) Anyways, I am one of those people that likes to do things right the first time. My goal for the project is to take the car apart and have it acid dipped, then galvanized and repainted original color (Adriatic Blue). I want to put the 78-83 SC Suspension on, 3.0L SC Motor with FI, bigger brakes and switch to a 901 side-shifter. The intended use will be street, show and maybe an occasional AutoX. Mostly it will be street and show. Overall, the car is in good shape. There is some rust, but it does NOT have cancer. Does anyone in Phoenix have a recommendation for a body/paint shop with acid dip facilities? How about Scottsdale Paint and Body? Any "documentary" web sites out there on those of you who have preceeded before me? Thanks, boxsterfan (probably should change my ID, but I think it is taken already.) |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Stud problem resolved, also did not beleive the flares wetre metal. We did not have a magnet to check, they are steel as well as the rockers and valances.
Great car, just sorting out a few minor things. CCLINCAMP914 |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
I think the best reason to go with a 3.2 over a 3.0 is drivability.
I would think about a 3.0 (carbed) for a race car and a 3.2 for a street car. The FI system is that much better with the 3.2. The 3.0 still uses the F'd up CIS. I hate CIS, it's blah. The 3.2 is much, much better. If you are afraid of ruining the tranny, just don't beat the hell out of it. my 2 cents. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Definately go with the 3.2L w/FI, makes a sweet ride. You say you are looking for a street/show car so go with the set up that is painless. The 901 can handle 300hp for quite awhile as long as you don't do burnouts in first gear.
I have also heard about the acid dipping residue being a problem to the welding seams. maybe Brad will chime in on that since he has done it a few times lately. Geoff |
boxsterfan |
Slowpoke,
Thanks very much for your input on the dipping process. I have heard that also, but thought the recommendation for the acid in the seams was to let the car "air out" for quite some time before continuing to the galvanize or re-painting process. Sort of like putting it up on a spit and rotating. I do know that the acid will drip out if not "removed" and destroy a brand new paint job. Other people who have acid dipped their cars chime in? I don't understand your logic on painting over galvanized steel however. Porsche has been galvanizing their cars since 1976, correct? Maybe the painting facilities in the aftermarket don't have the tools/resources to paint the car as the factory does????? ...and to be honest, I won't be putting the paint on. Someone else gets to do that part. Thanks, boxsterfan |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
The guy I have been talking with about dipping says there are three dipping stages 1- strip 2- neutralize chemicals 3- rinse with an inhibitor then bake it lightly prime and bake it some more...
I think that sounds pretty safe.. if not ridiculously expensive. M |
boxsterfan |
Seanery/bleyseng,
So many of you have been chiming in on the 3.2L over the 3.0L, that I am starting to come around. I am not a "burn-out out every stoplight" type of person so your arguments and Brad's are becoming clearer (after sleeping on it last night). Thanks, boxsterfan |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
QUOTE(boxsterfan @ Aug 7 2003, 12:51 PM) Thanks very much for your input on the dipping process. I have heard that also, but thought the recommendation for the acid in the seams was to let the car "air out" for quite some time before continuing to the galvanize or re-painting process. Sort of like putting it up on a spit and rotating. I do know that the acid will drip out if not "removed" and destroy a brand new paint job. Other people who have acid dipped their cars chime in? I don't understand your logic on painting over galvanized steel however. Porsche has been galvanizing their cars since 1976, correct? Maybe the painting facilities in the aftermarket don't have the tools/resources to paint the car as the factory does????? boxsterfan The acid dip is a gamble. No amount of "air dry" will remove it, it must be neutralized. Everything I have read from top flight restorers says: BTDT.....DON'T. Pretty much the same lessons that slowpoke has related. Media blasting is safe. The auto manufactures use pre-plated steel. This process was long and painful to develop. Getting paint to stick was the big challenge...along with getting the galvinize smooth enuff for a good finish. |
boxsterfan |
JP,
Thanks very much to you and all the boarders. I think I am going to start getting the estimates for media blasting and repaint. I am only cautious of one thing: I want to stop rust from coming back as much as possible. I am wondering if I should do my own POR-15 inside the areas of the body ("official " jack points, where the heater mufflers are, etc...)??? Before or after the media blasting? ...assuming after. |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
POR-15 after media blasting. Be sure to use a phosphorus-based metal etcher before the paint. POR-15 sells their own flavor of Metal Ready. I prefer Ospho (by Skyco) available at Ace Hardware for about 20 bucks a gallon.
-Rusty (IMG:style_emoticons/default/smoke.gif) |
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
carbs vs FI
Cold starting (carbs): brrrummmmm--thpt-thpt-buh (engine dies) brrrummmmm--thpt-thpt-buh (engine dies). brrrummmmm--thpt-thpt-rumrum-thpt-thpt-rumrum @ 1500rpm-2000rpm (until car warms up -- around 5 minutes) Cold starting (FI -- my guess anyway (IMG:style_emoticons/default/wink.gif) ): brrrummmmmrummrummrummrumm! Warm starting (carbs): brrrummmmmrummrummrummrumm! Warm starting (FI (IMG:style_emoticons/default/wink.gif) ): brrrummmmmrummrummrummrumm! That first start in the morning always sucks. (IMG:style_emoticons/default/huh.gif) get the 3.2FI (I will...after I blow up the 2.7...) |
Mountain914 |
Too much time in thin air! ![]() ![]() Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains ![]() |
I've got a 72 (they are lighter) with a 3.0L SC engine and C.I.S (K-Jet).
Nya Nya to all you 3.2 lovers, but it's mine and I like it !! You're right about C.I.S. though - It does provide a 'character' all its own. It was dynoed at 240horses, but a factory 3.0 should be about 180. I use a side shift 901 with an intermediate shaft stiffner and figure if I do blow it up I can go through a few 901's at a fraction of the cost of a 915 or other tranny. Mine was soda stripped and though most of you are tired of hearing it, I too have a great rear !! (IMG:style_emoticons/default/bootyshake.gif) And BTW - The flares / prep / paint were done near you: The shop is named Custom Auto Body and Fabricating 11210 N Cave Creek Rd PHOENIX, AZ 85020-1408 (602) 997-4985 If I could only have spent 20k - it would be less than half the car it is now. I think 30k is optimistic as well - but time will tell. You can always update the interior on your 70 to a 73 or newer (I did it on an old 72 I used to have). Figure out what' s right for you and go for it! Congrats on the new project !! Attached image(s) ![]() |
boxsterfan |
Mountain914, would you care to share your bodywork/paint costs? (privately)
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Every frame rail I have cut.. every body panel I have removed is rusting at the seams. None of the frame rails have paint in them.... the acid dip doesnt scare me. I know 6-8 people who have lost ENGINES because of "media" in the engine compartment surfacing at a later date and ending up inside the engine over time.
I would 100% media/soda blast a car that wasnt being color changed. The other reason for acid dip... it takes ALL the rust away and leaves me with what exactly needs to be repaired. Blasting will leave you with a ton of little holes to repair... the acid also gets rid of all the sound deadening on the fender corners and in the rear lip of the decklid... I want to be able to SEE the area's where rust typically starts. 3.2 all the way. Wife can drive it.. and not flood it or stall it easily. B |
jonwatts |
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 ![]() ![]() |
I don't suppose we'll get to see the acid dipped chassis this weekend?
Brad Roberts |
Not unless they call me tomorrow during the day to pick it up..
B |
Scott Carlberg |
Porsche MOTORSPORTS ![]() ![]() ![]() Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 ![]() |
Sorry, this is NOT about this topic,
just trying to get Brad to respond. Two diff attempts at brad@all914 have failed. Brad, can I go into a Topic that I started and Change the Topic Title & Description? |
Brad Roberts |
NO... but a moderator can (I'm off work right now)..
working on my MAIL server. B |
J P Stein |
QUOTE(Brad Roberts @ Aug 7 2003, 09:46 PM) I know 6-8 people who have lost ENGINES because of "media" in the engine compartment surfacing at a later date and ending up inside the engine over time. Blowing a motor due to ingesting blast materials into (or onto) it has got to be done only by the most ignorant mo fos....some kinda Darwin award (automotive section) winners. Maybe you could sell them idiots some air cleaners. Even the K&Ns will filter out the crap. |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
QUOTE(J P Stein @ Aug 9 2003, 11:21 AM) Maybe you could sell them idiots some air cleaners. Even the K&Ns will filter out the crap. I kinda have to agree. I grew up in Fremont Co. Idaho where we had about 50 sq. miles of sand dunes. We all had our sand toys (sleds, bikes, rails, etc.) and you don't loose engines to sand/grit because you make certain it can't get in. Sometimes that means putting a little thought into it, but it's not that big of a deal. -Ben M. |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:14 PM |
