Random AX Picts, Next N Cal AX is Aug 23-24 |
EdwardBlume |
Aug 7 2003, 07:58 AM
There's a lot of B in this car!!!
Attached File(s) ax3pict2 ( 31.96k ) Number of downloads: 0 |
EdwardBlume |
Aug 7 2003, 07:59 AM
blah
Attached File(s) ax3pict1 ( 33.02k ) Number of downloads: 0 |
EdwardBlume |
Aug 7 2003, 08:00 AM
blah blah
Attached File(s) ax3pict3 ( 39.08k ) Number of downloads: 0 |
EdwardBlume |
blah blah blah
Attached File(s) ax3pict4 ( 41.97k ) Number of downloads: 0 |
PatW |
Aug 7 2003, 08:44 AM
Wassup? Group: Benefactors Posts: 565 Joined: 19-February 03 From: Rocklin, CA Member No.: 317 Region Association: Northern California |
Looking good Rob, car looks like its handling right. (IMG:style_emoticons/default/cool.gif)
I'm thinking about showing up the next LPR Autocross. If I grovel enough can I have another ride?. (IMG:style_emoticons/default/boldblue.gif) |
cha914 |
Aug 7 2003, 09:15 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Looks good...and low!
what is your ride height? and your suspension setup + alignment #'s if you got em handy? or just point me to the thread where you already said all of this (IMG:style_emoticons/default/tongue.gif) Thanks, Tony |
EdwardBlume |
Aug 7 2003, 10:44 AM
I'm not quite sure. It's low though, mainly due to the tires and 140 lb rear. I have to drive up onto a 2x4 to get a floor jack under the car.
The alignment is off, but was set up at the beginning of the season with 1 deg camber, and some toe in. The front suspension has an aftermarket swaybar and bilsteins. I'm also in the rear swaybar camp for AXing. I run a stock rear bar. It's nice. All four shoes stay on the ground. Video to come once I get a new computer. (IMG:style_emoticons/default/cool.gif) |
J P Stein |
Aug 7 2003, 12:23 PM
I luv pics of 914s at work. (IMG:style_emoticons/default/clap56.gif)
silver six |
Aug 7 2003, 12:40 PM
Member Group: Members Posts: 203 Joined: 3-February 03 From: San Bruno, California Member No.: 227 |
How do I get in on the next AX? What sort of equipment do I need?
Douglas |
Brad Roberts |
Aug 7 2003, 01:26 PM
Cool.. now I know what we need to adjust Rob.. I needed to see the car going around corner.
I spoke with Doug...we will try to make the next event. B |
Andyrew |
Aug 7 2003, 05:17 PM
I'll probably be at the next ax. Looks like it was super hot!
EdwardBlume |
Aug 7 2003, 07:33 PM
QUOTE How do I get in on the next AX? What sort of equipment do I need? Just show up. The next AX is at Marina. If you have a helmet bring it, otherwise loaners are available. It costs $30 per day. Bring water and sunscreen. Info on the next AX is here. Zone 7 AX LPR/GGR Your car should be in good working condition (ie tires, wheel bearings, brakes, oil lines, etc) If you have questions, you can call or email me. Used to see lots of 914s out there. |
EdwardBlume |
Aug 7 2003, 07:36 PM
QUOTE I'll probably be at the next ax. Looks like it was super hot! I hope to see you there. How about a 914 this time? It's actually quite cool in Marina because its very near the ocean (Monterey). Its going to be a great time! (IMG:style_emoticons/default/smilie_pokal.gif) |
EdwardBlume |
Aug 7 2003, 07:38 PM
QUOTE Cool.. now I know what we need to adjust Rob.. I needed to see the car going around corner. I spoke with Doug...we will try to make the next event. The video will give you even more. The picture you see is in the last half of a 270. Definately try and make the event, I can't honestly say that I've ever seen you AX. For all I know, you're scared. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) I'm kidding. You're welcome to drive my car if you want. |
Joe Ricard |
Aug 7 2003, 08:46 PM
Maybe my eyes are playing tricks an me but those front rotors look bigger that stock. If so give us the details.
I had to go out to the garage and look at the boys car just to check. (IMG:style_emoticons/default/unsure.gif) |
Brad Roberts |
Aug 7 2003, 11:15 PM
His tire size is playing tricks on you.. they are stock.
B |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:50 PM |
