TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Will a 1.7 tps work in a 2.0? What is the diff in the two?
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,562 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I haven’t opened a 1.7L TPS, but I have opened a 2.0L TPS.
I can assure you that the wiring for both TPSs is identical. The 1.7L has 4 poles, the 2.0L also has only 4 poles, but the plug that fits into the TPS from the harness has 5 cavities, one is blank. Either way they use wires…in order…17, 30, 20, 9 from the ECU plug. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Anyone have a close-up pic of a TPS handy? I want a friend to take a look at it.
Thanks. M |
TheCabinetmaker |
Inside?
redshift |
Actually any picture at all.. maybe.
He said he may have an alternate TPS, and I don't have a car around to look at. M |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:32 PM |
