Electrical Guys Help - No Power to Fuel Pump, Could it be a bad coil? |
Oct 3 2005, 05:08 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
aha! now we're getting somewhere ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy |
redshift |
Oct 3 2005, 05:10 PM
Rock on!
Tip #12,943 Buy 2 relays. Throw one in the glove box, and swap one out with the fuel pump relay. Now, remove the cover from the old pump relay, and put that in a lil baggie, in the glove box. This is your test relay. With the cap removed, and the relay in place, you can acctuate it with your finger, press- wirrrr.... press- wirrrrr..... if the ignition doesn't acctuate the relay, but you can manually, it's the switch voltage not arriving at the relay.. I recently had THE EXACT same problem, that I chased for two years, not two full years... but over two ye.. nevermind! Rebuilt relay board... gone.. gone, gone, gone. M |
Lo-Fi Version | Time is now: 28th September 2024 - 07:25 PM |
