Wiring Diagram, Printout |
Maine914 |
Aug 7 2003, 09:40 PM
Member Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 |
Now that the engine, brakes and suspension finally seem to be working, its time to see if I can screw up the wiring. The prior owner put a viper alarm in such a way as to render the radio and heater fan inoperable. The viper wiring is like a cancer. Its everywhere. So, to make sense of this I'm looking for a wiring diagram I can take out to the car. The online diagrams at Pelican and the manual that was put online on this site look great on the computer but when I try to print them out, they come out in small, unusable scale. Does anyone know how to print them out in a bigger scale, even on several pieces of paper I can tape together, or where I can get good diagrams? Thanks. Paul
Brad Roberts |
Aug 7 2003, 11:12 PM
When you hit print... there is a "setup" option. You need to change the format of how the printer sees the picture. Typically there is a "best fit" option. This will stretch or collapse the pic to the paper size.
I would do some screen shots for you ..and show you what to do.. but I dont print from this computer. Look around at your printer settings... if you screw it up... it has a default settings checkbox. B |
Lo-Fi Version | Time is now: 20th June 2024 - 11:10 PM |
