914turboford |
Member ![]() ![]() Group: Members Posts: 74 Joined: 29-September 03 From: Pollock Pines, CA (near Tahoe) Member No.: 1,209 ![]() |
I think I will try to find a way to modify my steering arm so that I can run the outer end in double sheer and go with a 7/16". I have been looking on the web and have seen these turbo tie rod kits and bump steer kits. Does anyone know what size they run when they use spherical ends on the TTR's? However, I have not been able to find any specifications on them. It appears that the spherical bearings used on the TTR's are female. How do they handle running a bolt through the tapered hole? I was thinking I would use male rod ends and threaded tube for the tie rods. I have not seen it being done this way.
Thanks! I visit the board occassionally when I have something going on with the car. I drive the car when the weather is nice. No, I obviously did not sell it. I couldn't get anything for it. The bidding on ebay stalled out at $2550. Right now I'm glad I did not sell it. I have some non 916 flares in the rafters and plan on making a big scoop to stick over the Targa bar. Also, I plan to cut off the targa bar and make another roll hoop. I also have a 1999 Ford Ranger 2.5. I plan to use this crank to build a stroker motor. Hoping for 260+ hp. I plan to take the boost up to about 20 psi from the 14 I'm running now. Also, I'll probably run a Centerforce Dual Friction clutch. I slip my Escort clutch right not when the boost comes on in 4th or 5th. My latest project is a 1975 Volvo wagon 4x4 powered by a '97 Camaro V6. I might post an OT story about it here in a few days. |
BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
Lets see some pix's of the 914 with the ford 4 cyl. turbo install looks good from your avatar. (IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif)
Bob |
914turboford |
Here is a link to some photos of the car. I have an article I wrote about it if you are interested.
http://www.villagephotos.com/pubbrowse.asp...lder_id=1185384 Brian |
Lo-Fi Version | Time is now: 1st July 2024 - 06:07 AM |
