maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
I guess that is the radiator that provides coolant for the water-to-oil heat exchanger. At least I think that is what Turbo914V8 is saying. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
It is the AC condesor. Notice the crimped on AC fittings on each line.
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
Anybody ever able to connect with the UK 914 guy?
Wouldn't return any of my emails... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
I always wondered about that car (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
turbo914v8 |
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 ![]() |
Sorry all I am such a blockhead sometime; I was looking at the wrong picture. In an effort to gain more power buy decreasing the pulley size on the superchargers the inlet air temperature rose to critical so a liquid intercooler was added to reduce the charge air temp. The box you see on top. The unit in question is a small motorcycle radiator used to remove heat from the cooling liquid used in the intercooler.Cooler |
turbo914v8 |
I correspond with him regularly. Great guy but very busy. He is taking a well-deserved break from his 914. He is building, remodeling houses with his brother. That’s taking up all of his time now. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
I have an engman long kit sitting in a box! I have some other stuff in mind... Like a tube from the firewall to the suspension ear... Triangulating the shock towers to the trani points, triangulating the supsension points up front... and well... picking up all the suspension points... lol help? |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
andrew you should think about a way to tie the engine bay bulkhead [firewall] to a point in front of the doors close to the cowl area. a modified cage with out the main hoop would work. just reinforce all mounting points of the tubes with steel plate [ tube to firewall on both sides ].
turbo914v8 |
I also have the engman long kit sitting in a box. I plan on installing it before the cage. I have been tolled that the two combined is over kill, but after my last action hero move with chasse number 1. I think a little over kill is in order. |
Andyrew |
I agree..
Your engine is overkill so any chassi stiffening is NOT overkill in my book. especially if your running slicks. You running slicks? I plan on it. |
turbo914v8 |
Oooooohhh slicks. I would love to run slicks on the streets of Toronto, but unfortunately it’s highly against the law here and it is very heavily enforced and penalized if you’re caught with them on the streets. However on the track its free game. I have 16 x 12 and 16 x 13 rims rapped with street rubber on the car now, Should be able to hold 12 psi of engine boost = 700 + HP. This will be the street setting. (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
Lo-Fi Version | Time is now: 22nd April 2025 - 01:45 PM |
