Subaru transmission installation, Now it's a reality!!! |
MecGen |
Jan 28 2006, 05:42 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hey
For the speedo/VSS, its not that hard but a lot of research and testing, like you don't need more. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) For the 901 a VSS would have to be fitted, for OBD2 cars the VSS has become an input that the ECM uses for some realy important fine tuning. The VSS (from wherever you get it) would have to be the same type and signal strength, 1-5 volt square waveform ? You can program (reverse) the ECM to any tire size or gear ratio, but can't change the type of input. I have flashed many American cars/trucks, but never on a Suby. Lots of people do tho...I would lean to a Porsche/Suby hybrid sensor. +Karma Later (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Porcharu |
Jan 28 2006, 10:23 AM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
Maching after welding was always planned, I would expect some warping no matter how stout the flange was. I am more concerned with dealing with that hard as tool steel Suby CV. I can cut the sucker off with a cutoff wheel but I don't know how the thing will machine after that. Guess I will be the first to know. I might have to look into getting it EDM'ed. |
jimkelly |
Jan 28 2006, 02:29 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I wonder if the removeable output stub can be used in newer tranny (edit added the word tranny) one piece axles/cvs as steve has?
I so - in order to keep things as standard as possible should we not be bus axles/cvs with a custom flange on the wheel side and a custom sub splined roll pinned flange on the tranny side. The bus axles being shorter should give more spce for custom flanges - not to mention they are substantilly stronger and would be new - versus using used 914 axles/cvs? Also looking into the engine bay of my 1993 subaru impreza - it looks like the axles are not prependicular to the tranny by a substantial amount. Anyone want a pic?? Jim |
d914 |
Jan 28 2006, 03:09 PM
Advanced Member Group: Members Posts: 2,343 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
uuhhh!! Yes!
biggy72 |
Jan 28 2006, 04:12 PM
Member Group: Members Posts: 209 Joined: 14-January 06 From: Olympia, WA Member No.: 5,418 Region Association: Pacific Northwest |
if you're going to edm it I'd just get the custom axles because you're looking at quite a bit of money and alot of work to do all of that. I would guess after it's said and done you're looking at more money than the axles, (if they're only 350) and it's alot more work.
jimkelly |
Jan 28 2006, 04:33 PM
pic of my axle/cv from my 1993 subaru impreza. Not sure if you can see it but I can tell you it is far from perpendicular. Jim
d914 |
Jan 28 2006, 11:01 PM
small car has Hall effect sensor that fits on cv..... see below
This hall effect speed sensor fits on the transmission and a cv joint. It has 5 pulses per axle revolution which closely approximates the Subaru pulses per mile. Fits Syncro, 2wd manual and automatic SSK3 $49.95 Qty |
Porcharu |
Feb 5 2006, 01:18 PM
I hit a few minor snags during the first engine fitting. The release arm hits the trunk floor and the AWD extension hits the muffler heat shield. The heat shield can be trimmed to fit or hopefully the FWD casting can be used instead as it is much smaller, I'm looking into ths right now. The release arm issue could be solved with a small amount of cutting and a little sheetmetal box welded in to cover the hole. I am looking at hydaulic release bearings as a solution.
jimkelly |
Feb 5 2006, 02:25 PM
I'll be hanging on every word. Would be a shame if the awd tranny could not be easily used. Looking forward to the next episode : )
Porcharu |
Feb 5 2006, 03:48 PM
It will work, just needs a little help. Here are the pics I forgot to add in my last post. First one is the AWD housing almost hitting the muffler shield - the trans is about an inch too low in this picture. Attached thumbnail(s) |
Porcharu |
Feb 5 2006, 03:51 PM
And one of the release are hitting the trunk floor. I'm going to go out and remove the arm right now.
Does anyone have a suggestion on a decent easy to use "paint" program to draw simple shapes and text onto a jpeg. The only thing I have is a cludge of MS word and Photoshop elements. Attached thumbnail(s) |
Porcharu |
Feb 5 2006, 05:10 PM
Here is some more with the release are removed and the AWD extension removed.
Almost empty housing. Attached thumbnail(s) |
Porcharu |
Feb 5 2006, 05:11 PM
Top view of the whole thing.
Porcharu |
Feb 5 2006, 05:12 PM
Un-needed AWD housings.
Porcharu |
Feb 5 2006, 05:13 PM
"Stuff" sticking out of the trans. The splines get tied together with a coupler to make the AWD into FWD. The top splines are the pinion shaft the lower are the output of the transmission.
Porcharu |
Feb 5 2006, 05:15 PM
In the car. Fits MUCH better now. I hope the FWD housing fits. Otherwise I will cut (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) and weld (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) the AWD housing.
Porcharu |
Feb 5 2006, 05:17 PM
Clearance between the top of the bellhousing to the floor. Might be room for a cable release arm.
Porcharu |
Feb 5 2006, 05:20 PM
Last one for now. Side view that shows the trans tucked up nice and close to the floor.
My wife and I have been invited to a superbowl party so I have to go (IMG:http://www.914world.com/bbs2/html/emoticons/owned.gif) and waste time (I hate watching sports) and drink beer. (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) Attached thumbnail(s) |
jimkelly |
Feb 5 2006, 05:30 PM
That is some nice progress. Good job on the bracketing to hold the engine and tranny firmly and level on the jack - I hate seeing so many jack engines that are barely hanging on and can so easily be dropped and broken. Jim
Porcharu |
Feb 6 2006, 12:24 AM
Thanks, I figured that I should spend a little time making the engine/trans easy and safe to install and remove because I am fairly sure I will be doing at least 20 times. That's the first time I've used unistrut the way it's supposed to be used. Worked out well for a temporary deal. I hope to have rev 1 of the engine subframe done by the end of the week. |
Lo-Fi Version | Time is now: 24th November 2024 - 01:19 AM |
