Thursday, 3 April 2025
7 Pages V « < 4 5 6 7 >
> There sure are a lot of parts in a 901 box, Now I'm going to try to put them back in
DNHunt
post Nov 6 2005, 05:47 PM
Post #101
914 Wizard? No way. I got too much to learn.
I installed the 2 paper gaskets and installed the gear tack in the case. I used an old slider and my biggest pipe wrench to hold the pinion shaft so I could torque 1st gear. I know that looks gruesome but, it worked well.
DNHunt
post Nov 6 2005, 05:49 PM
Post #102
Gear stack done and intermediate plate installed
DNHunt
post Nov 6 2005, 05:51 PM
Post #103
Time for reverse. It starts with a roller bearing. The thrust washer remained on the shaft.
DNHunt
post Nov 6 2005, 05:52 PM
Post #104
Then a spacer
DNHunt
post Nov 6 2005, 05:53 PM
Post #105
Then a second roller bearing
DNHunt
post Nov 6 2005, 05:55 PM
Post #106
Reverse gear slips over the roller bearings and spacer. The staight cut gears go toward the case
DNHunt
post Nov 6 2005, 05:56 PM
Post #107
Another bearing
DNHunt
post Nov 6 2005, 05:59 PM
Post #108
Another thrust washer. This has a cut out machined into it that will overlap par of the race for the drive shaft in the intermediate plate. It's a bitch to keep on and oriented right. I used some grease to keep it in place.
DNHunt
post Nov 6 2005, 06:01 PM
Post #109
I removed the bolt from the speedo drive and pulled the drive part way out. It makes it easier to seat the rear cover.
DNHunt
post Nov 6 2005, 06:04 PM
Post #110
Torqued down the cover nuts and replaced the speedo and speedo bolt . Everything seems to turn really well.
DNHunt
post Nov 6 2005, 06:06 PM
Post #111
Reconditioning the shift console starts with removing the roll pin holding the fork.
DNHunt
post Nov 6 2005, 06:08 PM
Post #112
Take it apart and this is what you have. Getting the small seal in the console out is a little tough without a seal puller.
DNHunt
post Nov 6 2005, 06:09 PM
Post #113
Here is the seal for the rod
DNHunt
post Nov 6 2005, 06:10 PM
Post #114
The seal installed
DNHunt
post Nov 6 2005, 06:12 PM
Post #115
The larger plastic washer goes on the shaft before reinserting it.
DNHunt
post Nov 6 2005, 06:13 PM
Post #116
Inserting the rod in the console
DNHunt
Post #117
The top washer is the smaller plastic one.
DNHunt
post Nov 6 2005, 06:14 PM
Post #118
The fork goes on the shaft. The long leg goes toward the bottom and the 3 lugs point the same direction as the lever on the rod
DNHunt
post Nov 6 2005, 06:17 PM
Post #119
Tap in the roll pin
DNHunt
post Nov 6 2005, 06:18 PM
Post #120
Change the O-ring and istall the gasket and put it in. [Edit by McMark: No gasket. The gasket that looks like it goes here is for the tailshifter transmissions.]
- Lo-Fi Version Time is now: 3rd April 2025 - 03:39 PM
