DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Next, 2nd, 3rd shift rod! These bolts are only hand tight right now cause I'll adjust them later.
Attached image(s) ![]() |
DNHunt |
Next is the little peanut thing in the tube in the intermediate plate.
DNHunt |
After you shove it in you should be able to just barely see it through the 1st, reverse shift rod hole in the intermediate plate.
DNHunt |
Next the 1st, reverse shift rod and shift fork go on with the bolt finger tight.
DNHunt |
The 3rd and final ball goes in the tube
DNHunt |
Then the stiffer of the 2 springs
DNHunt |
You can see the last spring in the hole
DNHunt |
The plug finishes it up
DNHunt |
Done with that
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
Very cool stuff
DNHunt |
This is a side shifter!!!
Adjusting the shift forks for 2nd, 3rd and 4th, 5th can be done now. The balls and springs will hold the shift rods in neutral and the alignment jig supports the free ends of the rods. You should be able to see all of the notches in the shift rods lined up. Like this Attached image(s) ![]() |
DNHunt |
The jig holds everything nice and steady
DNHunt |
Tighten the bolts when the sliders for 2nd, 3rd and 4th, 5th are centered between their respective gears. Here is what 4th, 5th should look like.
DNHunt |
Haynes manual calls for 1mm clearance between the back of the slider and reverse on its' shaft. Once I got that I tightened down the bolt on the shirt fork then rechecked it.
DNHunt |
The gear stack is now ready except for torquing the 30 mm bolt on 1st gear.
DNHunt |
The paper shims for the intermediate plate were not colored and the replacements in the gasket kit are not either so I had to measure them. I chose a none compressed area in each. There are passages or something where the castings are not solid and the sealing surfaces do not compress the shims. The old ones added up to .015".
DNHunt |
One old shim measured .009"
DNHunt |
The other old one was .006
DNHunt |
It just so happens that there was an .009" in the gasket kit.
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Attached image(s) ![]() |
DNHunt |
And lucky me an .006. I guess I'm good to go.
Lo-Fi Version | Time is now: 2nd April 2025 - 11:38 PM |
