qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
anyone use this on their case?
What do you use where for rebuilds? Case? Jugs? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) love that word pushrod tubes? etc? |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
what references are you using for the rebuild?
Jakes video, the Haynes manual, factory manual ?? or ?? |
qa1142 |
Reference? 30 years of working on cars including a 79 westfaila 2.0L rebuild
Plus I do have Jake's video Plus air cooled vw manual Plus hayes Plus Brad Mayuer What do you recommend? (or who) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
use the raby vid
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
I put a lot of effort into the video to cover the things that no manual covers... They don't show you hidden bolts that keep you from destroying your case!
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
Jake: is your avatar the face you made when you found the bolt behind teh flywheel?
PS. when is the T-4 HP trick video comming out? |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
I've used it several places. It sets when there is no air in contact with it so you can put it on and let it sit on unassembled parts for a little while. That makes it great for case hardware like washers nuts and bolts.
518 can allow you to seal without a gasket. That makes it great for a lot of appended stuff like cam plug, oil pump, oil filter housing, taco plate but, not the O-ring. Be aware once it's deprived of air it sets up pretty fast and it's a bitch to clean off of parts once it's set. Cleanup of unset stuff is a snap so you can do a real neat job. Don't try to seal the case with it. It sets up too fast and it will be too thick. I think you will do better with something that doesn't harden. I've heard of Yamabond or Kuril K2 and a few others. I think Shoptalk Forums has a lot on this. Great stuff. Dave |
KevinP |
Member ![]() ![]() Group: Members Posts: 205 Joined: 16-November 04 From: Orlando,FL Member No.: 3,127 ![]() |
I've been using Yamabond #4 for the last 30 years and found that it works great on case halves. Easy to find and, I think bike cases take alot more vibrations and abuse than our TIV's.
------------------------------ KP |
Jake Raby |
DO NOT USE IT ON THE CASE!!!!!
Doing so will create a bond that will make your case halves virtually inseparable for 1200 hours- Thats what it's designed for in the Aviation world. Curil K2 is my case sealant of choice... BTW_ I'm only awaiting the artist to finish his part of my sealants guide, it should only be a few more weeks... I lost 40% of the guide when a power surge killed my entire network, it should have been done by now. |
Lo-Fi Version | Time is now: 29th June 2024 - 01:19 AM |
