Loser_Cruiser |
Member ![]() ![]() Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest ![]() |
Does this mean that if I were to buy your kit, you guys would have to install it or would I be able to order and install it at home? I understand that you dont want to get ripped off but before Im willing to drop 2000 dollars on something I definately want to see it first. Since I wont be going to Las Vegas till at earliest late next summer, the only time I may even see this is if you go to WCC next year in portland. Also what is to stop people from buying your kit then coping it that way? |
mike373 |
Member ![]() ![]() Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 ![]() |
Srbliss......If your kit is less than renegade's kit, you can count me in. Will you be making the radiator brackets, and everything with full install instructions?
guiltless |
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-August 05 From: Dana Point Ca Member No.: 4,552 ![]() |
It seems to me that the obvious choice for a higher HP motor would be a stand-alone engine management system a la TEC3, or something like that. No dealing with the Suby ECU and Harness and near infinite tunability to boot.
For the extra that it costs I think that it is totally the way to go. Less hastle, better performance. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
mongrel-gs |
Member ![]() ![]() Group: Members Posts: 55 Joined: 29-November 04 From: Baltimore, MD Member No.: 3,194 ![]() |
Heat was one of the first things I though about with my conversion... I didn't like when I had to ride with a credit card in one hand driving the ghia in the winter to scrap the breath frost from the windshield.
Summit has 4 or 5 different heater cores/blowers, all for less than $200. I bought the cheapest one(made by Southern Hot Rods), mounted it under the trunk just behind the starter. Duct(from McMaster) to the stock inlets at the firewall, heat is good but the cheapest heater does have a cheap blower. I'd recommend getting the Summit brand, more btu, 3 speed blower. I have the heat working(and the amp/subwoofer for that matter) but still have error codes to fake, you can see where my priorities are. And yes, the heater circuit has to be hooked up, either with a heater core or bypass loop, for the cooling system to work. Evan |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
Okay, didn't mean to start a flame war. When I said using air was a horrible idea, I meant given the choice between water and air, which is the case for a Suby conversion. Also, I guess I should have searched the archives before posting; I didn't realize that the stock 914 heat system was so widely and passionately praised for its effectiveness.... |
Lo-Fi Version | Time is now: 26th June 2024 - 12:47 AM |
