Twisted gauges?! Cool or lame...?, ...thinking about 904 kit... |
jgara962 |
Nov 10 2005, 06:48 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Most race cars do. Not only is it easier to see with a small steering wheel, but your not trying to read a number in the heat of battle. The needle goes completely verticle - you shift.
Rand |
Nov 10 2005, 07:11 PM
The speedo cable is long enough that a little twist shouldn't be a problem if it were spread far enough along the cable.... is there a clamp that could be loosened to let the cable housing rotate a little so the twist isn't forced to a short section of cable housing at the speedometer end?
Lo-Fi Version | Time is now: 26th June 2024 - 09:48 AM |
