> Mueller bearing install and 5 lug conversion, The time has come
Leo Imperial
post Nov 17 2005, 01:48 PM
Do you have to use so many cuss words?
So I won these parts at the WWC05'. I didn't even know at first what they were, but it didn't take long for the flock to move in and start making offers. Well I decided to do some research and I started collecting parts.
The front end has all been removed including the steering assembly. Turbo tierods will be part of the rebuild. The current swaybar is a 22mm adjustable upfront and will remain. I am keeping the stock 18mm torsion bars and a-arms. Everything else is being refreshed or replaced.
When the front is done the rear will be converted to 5 lug and a rear swaybar will be installed. Also if they can be obtained a set of Mueller bearings.
So here is the first set of pictures and questions fo Mike.
Leo Imperial
post Nov 17 2005, 01:51 PM
So here is the test fit in pictures.
Leo Imperial
post Nov 17 2005, 01:52 PM
Perfect fit!
Leo Imperial
post Nov 17 2005, 01:53 PM
I mean this is a perfect fit.
Leo Imperial
post Nov 17 2005, 01:54 PM
Washer
Leo Imperial
post Nov 17 2005, 01:55 PM
Roller
Leo Imperial
Washer
Leo Imperial
post Nov 17 2005, 01:57 PM
The bearing
Leo Imperial
O-ring
Leo Imperial
post Nov 17 2005, 01:58 PM
And the front mount.
Leo Imperial
post Nov 17 2005, 02:00 PM
Now to grease it all and do the actuall install.
Any advise from the peanut gallery. Mike is this looking like the correct approach?
BTW - everything fits perfect. No forcing and no play.
Mueller
post Nov 17 2005, 02:01 PM
914 Freak!
Look'n good...make sure you lube the living daylights out of the bearings before the final install..........
Leo Imperial
post Nov 17 2005, 02:03 PM
Is this the type of grease you would use or should I get something else?
maf914
post Nov 17 2005, 02:19 PM
Not a Guru!
I'm just a casual observer of the various bearing threads from the past, but I thought Mike or another bearing user had recommended marine grade grease (boat trailer wheel bearings) for water resistance. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Leo Imperial
post Nov 17 2005, 02:25 PM
That was what I had read also.
This stuff makes the same claims as the others on the shelf (water proof).
The other option is synthetic, but is that really neccessary?
Mueller
post Nov 17 2005, 02:27 PM
914 Freak!
QUOTE (maf914 @ Nov 17 2005, 01:19 PM)
that looks like standard wheel bearing grease which should be fine, I've never run into a wheel bearing grease that is water soluable (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
the main difference with marine grade grease is the protection from thermal shock when backing your trailer into the water after a long drive...(read it someplace, how true, no real idea)
airsix
post Nov 17 2005, 02:39 PM
I have bees in my epiglotis
Does the sleeve that the large bearing runs on have to be epoxyed to the arm to keep it from walking or spinning?
-Ben M.
McMark
914 Freak!
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Part of the marine grade grease recommendation was that it's much "stickier" than other greases and seems like it would stay in place longer.
Aaron Cox
post Nov 17 2005, 02:40 PM
Professional Lawn Dart
QUOTE (airsix @ Nov 17 2005, 01:39 PM)
-Ben M.
good question.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Leo Imperial
post Nov 18 2005, 02:18 AM
I have alredy done the install with this shit.
Should I be concerned?
- Lo-Fi Version Time is now: 29th April 2025 - 11:13 PM
