Maine914 |
Member ![]() ![]() Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 ![]() |
Just got some seals from Tweeks for the trunks. The remnants of the seals on the trunks seem to have fit right on without glue. The replacements don't go right on. Is it glue time?
Any advice on putting the squeegies on the windows and the rear window seal? Thanks |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
I put dish soap on the side squeegies and pull them into place with plyers. Put a bit of water in the track and moisten the squeegies after soaping them. They will go on like butter!
The rear window I did when I had the window out so I have no input on that! Jeff |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
The rear window seal has a metal clip inside the seal, you need to get iton and once stated it goes fairly quick. Do not glue on any of the rubber seals that go on the trunk, they also have metal clips inside and slide down over the lip on the trunk, you may need to use a hammer(soft) to get it started.
The squeeges go on after you remove the very small screws that hold the window top guide caps on, there may also be an inner screw, caereful easy to lose down the window channel. They slide in rather easily after you lube them , soap , silicone spray,WD40, whatever works for you. CCLINSEALLAND |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
use glycerin and be generous, any drug store should have it. the window squeegees will slide right in from the handle side of the door, 10 min. trim them after you install for a tight seam to the end cap, get those also if you have the dough. i did the new side and top seals yest. i split the old ones with a utility knife to remove. they don't slide as easily. place the outer groove over the trim piece lip. then work the inner side edge in with something that will not cut/mar the new rubber, 15 min. bye, bye squeeky top and rattely windows. new vert felts are next on my hit list. why do these cars leak? i had never seen "new" seals. there is a little second flap that covers the window edge.
kevin |
makinson1 |
Member ![]() ![]() Group: Members Posts: 50 Joined: 13-August 03 From: Tallahassee, Fl Member No.: 1,021 ![]() |
The front of the Targa top seal at the windshield. Top piece that runs all the way across. Anybody have a small piece of this stuff? The PO cut it about an inch too short!?!
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Maine..
Did you find the parts you need for the Dells ?? CB Performance carries everything you need for the Dells. B |
Maine914 |
The seals on the rear trunk are on. I took a look at the front trunk...I assume I use some sort of glue for that. Also, one of the rails is rusty... are replacements hard to find?
Also, CB Performance is good but they have a $20 minimum, and all I need is the threaded linkage rod. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Targa side seals do not 'slide in'!
They are installed by feeding the inside lip first, then pushing the outside lip in-and-under, back to front. M |
Maine914 |
It is not the targa seal. It is the front trunk seal. It seems glue is necessary? Is that right?
Thanks |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
They are designed to be glued. Most people don't glue them. The glue traps water under the seal & rusts out the seal flange.
redshift |
QUOTE(Maine914 @ Sep 1 2003, 04:52 PM) It is not the targa seal. It is the front trunk seal. It seems glue is necessary? Is that right? Thanks Yes, I was pointing that out from another message up the ^ thingy here.. M |
Lo-Fi Version | Time is now: 30th June 2024 - 12:46 PM |
