3 Pages V < 1 2 3 >
> Remove dash top, step-by-step
bondo
post Dec 14 2005, 09:41 PM
Post #21
What if you have an early car with no dash side vents? Those holes come in handy.
markb
post Dec 14 2005, 10:01 PM
Post #22
914less :(
You can get to them, it's just a little tougher. You don't have the vents in the way, so once you have the instruments moved, and the glove box out, you can get to the nuts.
boxstr
post Dec 14 2005, 10:40 PM
Post #23
One thing you will find is that some of the nuts are alloy, and not always nylon.
Great thread.
CCLINCOMPLETYLEYNUTZ
jfort
post Dec 15 2005, 07:36 AM
Post #24
thanks for the documentation and especially the pictures. the more of this type of thing the better!!
Bartlett 914
post Dec 15 2005, 08:02 AM
Post #25
Great thread! I was getting ready to do this myself for the first time. You just took a lot of the guesswork out.
Mark
tat2dphreak
post Dec 15 2005, 09:12 AM
Post #26
stoya, stoya, stoya
QUOTE (Bartlett 914 @ Dec 15 2005, 09:02 AM)
Mark
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) this is one of the most frustrating things to do the first time, a good walkthrough like this helps a ton... good job!
rhodyguy
post Dec 15 2005, 09:26 AM
Post #27
great write up and photos. perfect opportunity to clean the fresh air fan contacts too. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
k
Tobra
post Dec 15 2005, 11:55 AM
Post #28
Very cool, you must have small digital camera and little hands for some of those picks. Can you get the seal between the dash and the windshield out with the dash removed, or does the windshield have to be out too?
Aaron Cox
post Dec 15 2005, 12:02 PM
Post #29
Professional Lawn Dart
QUOTE (Tobra @ Dec 15 2005, 10:55 AM)
its replaceable with the dash in...AND the window in.... ive done it
Jeffs9146
post Dec 15 2005, 12:14 PM
Post #30
Ski Bum
You don't even have to take off the wheel!
grasshopper
post Dec 18 2005, 06:52 PM
Post #31
well, i used this thread, and it worked great!! Since i am completely stripping this car, i decided to add to your thread, and remove the dash frame under it. it only took me about an hour. first, you need to remove all of the switches, the steering wheel, and disconnect all the other electrical connections, and pull them down below
With the steering wheel off, and the switches pull out of the back
grasshopper
post Dec 18 2005, 06:57 PM
Post #32
next, remove the fresh air control unit in the dash. There are two ...8mm? nuts holding the cables to it, and a 10mm nut holding it to the body. Pull it out the front. Next, remove the steering column: there are four 7mm allen bolts holding it to the body
grasshopper
post Dec 18 2005, 06:58 PM
Post #33
with the nuts out
grasshopper
post Dec 18 2005, 07:00 PM
Post #34
disconnect the universal joint: 13mm bolt, and 14mm nut
grasshopper
post Dec 18 2005, 07:02 PM
Post #35
with it removed:
grasshopper
post Dec 18 2005, 07:06 PM
Post #36
next, remove the two upped dash vents. They seperate from the larger units in the front trunk, with two clips. Push them up a little, and pull them down and toward the front of the car. The drivers side can be a little tight, but it is possible with the gas tank in...i did it, you just have to wiggle it around alot. With it out
grasshopper
post Dec 18 2005, 07:08 PM
Post #37
next, remove the two screws on each side of the dash, right next the the air vents... on earlier cars, these screws should still be there..??.. i dont know
grasshopper
post Dec 18 2005, 07:10 PM
Post #38
now your dash should look like this, you need to remove the two screws pointed out here, too. I would have missed that, but michel reminded me
grasshopper
post Dec 18 2005, 07:12 PM
Post #39
remove the 10mm nut under the dash, connecting the dash frame to the body. This nut isn't hidden, it is right in the middle, but this is a bad pic.
grasshopper
post Dec 18 2005, 07:17 PM
Post #40
now there are only four more nuts holding the dash frame on. You will need to remove the nut holding in the windshield washer fluid bottle, and pull it forward. Then you should be able to get to the first nut. It is a 10mm nut. It is right next to the tube that feeds the fresh air vents in later cars. The nut:
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2025 - 01:38 AM
