13 Pages V « < 11 12 13
> How flexible do you think a stock, trailing arm is
ChrisFoley
post Jan 18 2006, 06:53 PM
Post #241
I am Tangerine Racing
As far as ignoring the twisting forces -- I'm not there.
I'm not suggesting ignoring any twisting forces. The 1390lb vertical up is the component that pushes straight into the trailing arm. It is the part of the "weight" that does not exert ANY twisting force. If you want to include it, break it up and apply it at several nodes on the bottom the trailing arm That would eliminate any point loading.
All the twisting force is included in the 910 ft lb. What's wrong with multiplying the torque by the fraction of a foot node 284 is from the axis? This eliminates any extraneous structure that might deform under the load.
My last graph shows all the forces being applied at what I labeled point A (an imaginary point on the longitudinal axis of the trailing arm). You just need to figure out how far node 284 is from the axis.
The horizontal force can be applied at node 284 since that is in a direct line with the axis, as viewed from the side.
ChrisFoley
post Jan 18 2006, 07:12 PM
Post #242
Maybe this will help.
Imagine that all three arrows I drew are in the same plane as node 284.
The vertical up arrow needs to be a force of 1390lb.
The horizontal arrow needs to be a force of 810lb.
The vertical down arrow needs to be a force of 3600lb!!! That's right. It is only 3 inches from the centerline of the trailing arm box.
jluetjen
post Jan 19 2006, 07:43 AM
Post #243
OK. Here you go -- although I fear that we might be going down a "rat hole" with this approach. The reason is that I fear that we're trying to kluge the computations which are already inherent in the model. At the end of the day I don't believe that it really tells us any more, but could very well confuse us more. Kind of like if you wear one watch -- you're always pretty sure what time it is, but if you wear two watches you'll never know what time it is. In this case we'll get another set of numbers, but since they ignore braking and other lateral forces -- of course they'll be different.
The picture below is looking at the arm from behind the shock mount and is a little busier then normal to show what was done.
Forces: Per Chris's diagram above.
Constraints: Both front pivots are constrained in all three directions -- X, Y and Z. So those points won't move. I had to constrain the shock mount in the vertical (Z) direction to keep the model from flying all over the place. I'm kind of concerned about his since this constraint is only a couple of inches away from where we're applying the vertical forces. Essentially I'm concerned that I'm over constraining the model.
Results: The model is still bending along it's length. While I follow Chris's vector math, I don't believe the way that the forces are being applied to the arm accurately reflect the environment the arm is in. For example, the arm never sees a positive Z force at the bottom of the arm -- but our model has such a force. So we're essentially solving a problem that doesn't exist from a mathematical perspective.
I think a better way to cross check the model and help develop a test methodology would be to do the vector math as of point 284. Basically do the math so that the answer results in a single torque being applied at point 284. This answer can then be used to mount a beam at a given angle from X/Y/Z which Chris can then fabricate and test with. I'll try giving it a shot later today.
jluetjen
post Jan 19 2006, 07:54 AM
Post #244
And one more view that reflects Chris's mark-up above.
ChrisFoley
post Jan 19 2006, 08:02 AM
Post #245
Here's the updated data table resized to fit.
ChrisFoley
post Jan 19 2006, 08:31 AM
Post #246
OK. Here you go --
I like what I see now. I do still have a couple of minor issues:
1) Can you reduce the displaced skeleton view to 10x instead of 100x. I think that it over-dramatizes the situation currently.
2) I want the outboard pivot location moved closer to node 284. The pivot axis properly should be perpendicular to the inner box surface. The distance of node 284 from the pivot axis will be approximately correct with this change.
3) I'm picking nits now, but - since the arm is mounted to the car with the pivot axis at a 12.5 degreee angle the tube connecting node 284 should be at such an angle, the lateral force should also be at the same angle, and the vertical up force should be moved forward a corresponding amount.
These changes would satisfy me that we have modeled a trailing arm as well as GRAPE can do for us within reason.
... but since they ignore braking and other lateral forces --
The braking force will never be applied simultaneously with the other forces, and is much smaller as well.
... the arm never sees a positive Z force at the bottom of the arm...
It does, but by the time it gets there it is spread out instead of point loaded. How much does the arm bend in this direction? Maybe this should be measured on a real trailing arm.
... do the math so that the answer results in a single torque being applied at point 284.
I'll look at that to see if it is possible, but I don't believe so. I think the three components I derived constitute the easiest way to input the actual forces into the model. (Adding the braking force would definitely complicate things unnecessarily.)
Brett W
post Jan 19 2006, 08:38 AM
Post #247
One thing to keep in mind is the shocks will provide no lateral location of the trailing arm. So restraining the shock mount will provide no usable data.
ChrisFoley
post Jan 19 2006, 08:45 AM
Post #248
One last point for now, the rotations listed in the table don't accurately reflect the real world. I don't think this means the model isn't accurate, only that the point about which the rotations occur isn't modeled accurately. If possible, it would be better to tabulate the angular change (in 2 axes) of the surface that node 284 is at the center of.
That's why the constraint for this point is only in the Z direction.
jluetjen
post Jan 19 2006, 09:12 AM
Post #249
QUOTE (Racer Chris @ Jan 19 2006, 06:31 AM)
QUOTE (jluetjen @ Jan 19 2006, 08:43 AM)
OK.  Here you go --
These changes would satisfy me that we have modeled a trailing arm as well as GRAPE can do for us within reason. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Chris!!! Now you're "gilding lillies". (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) How is any of this going to change the strategy that you use for modifying the trailing arm?
Brett W
post Jan 19 2006, 10:19 AM
Post #250
Duh! My bad, I should have read closer. (IMG:http://www.914world.com/bbs2/html/emoticons/chair.gif)
ChrisFoley
post Jan 19 2006, 04:59 PM
Post #251
Chris!!! Now you're "gilding lillies". How is any of this going to change the strategy that you use for modifying the trailing arm?
LOL! I can ask can't I? (IMG:style_emoticons/default/biggrin.gif)
Actually, I expect that moving the outer pickup rearward, and inputing the lateral force at 12.5 degrees will have a noticeable (I don't know how significant though) effect on the data output from the model.
As long as I'm asking for the moon, I would also love to see the effect of the lateral force by itself, and the torque force by itself.
John, can you explain what calculation is used to produce the rotation numbers in the table? Do you have control over that calculation?
jluetjen
post Jan 19 2006, 05:50 PM
Post #252
LOL! I can ask can't I? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif)
Actually, the front pick-ups are aligned correctly against the body of the arm. The rear hub assembly was not offset by an angle -- so that's the angle that is not reflected. Moving that back by ~6 degrees is not going to make a huge difference since the large diameter tube that the hub is attached to connects to the arm across a wide area.
How do I say this nicely?.... No.
Dammit Chris! I'm a salesman -- not a mathematician. That means I was smart enough to recruit to my team (aka: marry) an engineer with a master's degree who grunted through 6 years of advanced college level math rather then take the classes myself.
The other thing that I learned in B-School (in addition to strategic acqusitions) is delegation.
I just emailed to you a copy of the software and the base model. (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif)
BTW: Grape is Shareware that can be downloaded from the Grape Software web page.
jluetjen
post Jan 19 2006, 06:23 PM
Post #253
Oh yeah, here's the latest data table. Note that the rough order of incremental improvement for each strategy is consistent even as we change different force strategies. To my simple mind this suggests that the results will be fairly consistent even if you change an angle here or a few pounds there.
ChrisFoley
post Jan 19 2006, 08:48 PM
Post #254
Hold a carpenter's square against the inside face of the box section and you will see what I am getting at.
John, for a salesman you make a pretty good engineer. I have been impressed with the depth you go into this sort of analysis. I really appreciate all you have done and I will find a way to repay the favor down the road. 0
I'll see if I can pick up where you left off on the model (unless I can get Tim to do it (IMG:style_emoticons/default/biggrin.gif) ).
Thanks!!
jluetjen
post Jan 20 2006, 09:09 AM
Post #255
Ok -- I've been thinking that we're starting to "lose the forest for the trees". This is going to be a real challenge -- I'm going to try to be brief. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Using FAE to figure out if the answer is 0.00498 versus 0.00484 is most likely not an effective use of the tool. If you want to know the meaning of life -- it's
42. (IMG:http://www.914world.com/bbs2/html/emoticons/WTF.gif) But what is the question???
To answer that I went back 243 posts to look at where we started and found these thoughts:
How flexible do you think a stock, trailing arm is? -- Specifically I am looking for rotational stiffness (ie. twist) of the trailing arm due to the tire contact patch resisting sideways sliding of the car. I'm only interested in forces greater than 1G during cornering.
and...
you could take your invesitgation to another level, and find where the trailing arm needs to be reinforced.
and...
I only want it to limit the flex from cornering loads.
and finally this fairly pithy problem statement:
A stock trailing arm definitely isn't stiff enough for a competition car running on slicks.
((IMG:http://www.914world.com/bbs2/html/emoticons/yawn.gif) If you want to jump to my proposal and skip the long winded monologue, it's at the bottom.)
What we've learned along the way since they consisentanly came out in our tests and model -- no matter what we did to them.
1) The stock arm does flex.
2) Adding an internal bulkhead stiffens it some.
3) Adding an external gusset stiffens it more.
4) Combining the two approaches stiffens it even more
5) There are some concentrated stresses in the hub area (where Porsche's designers kindly designed in a fairly massive piece) and where the arm attaches to the outer end of the front pivot tube.
Some things that we already knew
1) Weight is evil
2) Stiffness increases with the cross sectional area and to a lesser degree by filling in internal voids.
Putting these factors all together I modified the spreadsheet to take into account the extra material being added by each solution (assuming it's all 2mm thick steel) and then compared this to the reduction in Y-displacement and Z-Rotation (which both impact toe). I then tried to optomise the solution some based on the earlier approaches and rather then combining the external gusset with an internal "floor", I tried triangulating the top edge of the gusset to the corners of the arm's original box section. The result?
A solution that is stiffer then all of the previous options, but uses less material then the next stiffest option. But even though, the best "stiffness versus weight gain" option remains the original simple external gusset.
My Final Recommendations!
1) For the lightest solution, weld a lengthwise external gusset to the arm.
2) For the strongest solution, weld additional pieces from the exposed edge of the gusset down to the arm, thus creating a "peaked roof" type of structure.
No matter what you do, doubling the thickness of the material in the area near the outer half of the front pivot tube will essentially cut the surface stresses in that area by half (same stress, double the material) which is a good thing.
Now back to my day job! (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
jluetjen
post Jan 20 2006, 09:11 AM
Post #256
Here's the overhead view of the gusset with the "peaked roof" results.
jluetjen
post Jan 20 2006, 09:17 AM
Post #257
A view from the outside of the arm (when mounted) showing the area of highest stresses.
jluetjen
post Jan 20 2006, 09:18 AM
Post #258
Finally an "edge on" view showing the "peaked roof" structure that I discussed showed the best stiffness improvement.
- Lo-Fi Version Time is now: 11th June 2026 - 10:34 PM
