2.5 shor stroke engine, my plans |
TimT |
Dec 22 2005, 03:52 PM
carr914 |
Dec 22 2005, 06:12 PM
Racer from Birth Group: Members Posts: 122,848 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Michel,
7R case 2.2 rods 2.7 heads JE custom design pistons 2.2S crank custom cams 40's Kerry Hunter headers into megaphones Crankfire twin-plug compression 10.5 230hp @ flywheel 185ft/lbs @ 3,500 T.C. |
michel richard |
Dec 22 2005, 07:05 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
T,
do you have you rport size ? your jetting ? When you were Dyno-ing, did you get info on the richness of your mixture (O2 readings)? Rod bolts? What do you use as a redline ? Thanks, Michel |
Trekkor |
Dec 22 2005, 07:15 PM
Yes, that sounds like quite the mill. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
KT (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) |
Lo-Fi Version | Time is now: 9th January 2025 - 05:36 AM |
