Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
The castle nut.... hahhahahahah!
I did that LAST weekend. An impact wrench didn't do it alone. I had to heat the nut with a torch, and break it loose. It took several heat/impact wrench sessions. A 4 foot breaker bar didn't phase the castle nut with all my weight on it. Keep us posted and welcome to the group. Good luck! |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Oh, and remember to remove the cotter pin first.
...Don't ask me how I know to check that... (Thankfully it wasn't the axle nut, but it was plenty bad enough!!) --DD |
jwade |
Member ![]() ![]() Group: Members Posts: 94 Joined: 23-February 03 From: Los Angeles, CA Member No.: 340 ![]() |
Liquid wrench and a two foot flex bar and the castle nut came right off.
If only the rest goes as well! Pep Boys has the axle that I can special order so all I need is the 12 point wrench to get the CV bolts out. wish me luck (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 12:32 PM |
